Cheap Android Head Unit Review!
Old 05-03-2022, 12:01 AM
  #556
myw
myw's Avatar
do ALL pcm 3.0 (bose + non-bose) require a MOST adapter? they are all digital output *only*?
for some silly reason , i always under the impression that the non-bose cars would be analog audio output, but i am realizing now that it's only 997.1 pcm 2.1 non-bose that have RCA analog audio output.
Originally Posted by CRD
That was my question. I don’t think these head units come with a MOST adapter. All the ads for them don’t show one. You most likely have to purchase one separately. Bummer as these aren’t cheap.
Pedro Lopes (05-03-2022)
Old 05-03-2022, 05:04 AM
  #557
Pedro Lopes
Pedro Lopes's Avatar
This one should work?
https://pt.aliexpress.com/item/10050...73761140%7Csea
Old 05-03-2022, 05:42 PM
  #558
Pedro Lopes
Connected everything still no sound.
Should I connect these 2 blue wires?
Old 05-05-2022, 06:48 PM
  #559
Pedro Lopes
working with sound in 997.2 Non-BOSE
SOUND is good quality, after all was plug and play ANT-CONT blue cable to AMP-CONT blue white stripped cable.
it has night mode
myw (05-06-2022)
Old 05-08-2022, 09:52 AM
  #560
Pedro Lopes
Originally Posted by Barry987
Hi
Genius Went into factory settings reverse was disabled, enabled it. Tried reverse with pink wires joined, nothing. Put +12v on pink HU input result., camera works a treat. I have a WiFi camera with no trigger so I have to replace the sender and receiver with a trigger type. But I am very happy, it's a pity OWtosin didn't give me this information after a week of to and fro messaging blaming me and or the camera.
many thanks
Barry
Can you post your wifi camera? want the same solution for mine
Old 05-08-2022, 10:18 AM
  #561
Barry987
Barry987's Avatar
Hi Pedro
Got one of the Porsche license light camera from Ali Express like this
https://fr.aliexpress.com/item/32835...5-d542b847ec12
works well and is a cheap solution.
Barry
Pedro Lopes (05-08-2022)
Old 05-08-2022, 05:42 PM
  #562
Pedro Lopes
Hi Pedro
Barry
Hi the link didn't work here. And the wifi adaptor? thanks
Old 05-09-2022, 03:16 AM
  #563
Barry987
Barry987's Avatar
Hi Pedro
Just go onto Ali Express and search Porsche Cayman rear camera. As I said in my previous posts I could not make the wifi adaptor work because I still needed the trigger signal from the reverse light. It was fairly easy just to hard wire it and it works perfectly now.
Barry
Pedro Lopes (05-09-2022)
Old 08-12-2022, 10:09 PM
  #564
CRD
CRD's Avatar
Hi Pedro,
I purchased the same Android head unit as you did. It looks exactly like the one in the pictures you posted. Everything works great after the install but I cannot find the trigger wire do the back up camera as there are no pink or labeled wires.
were you able to get your back up camera working?
Old 08-13-2022, 12:07 PM
  #565
myw
myw's Avatar
if you have a 997.1, the canBus will NOT detect the reverse trigger. ONLY on the 997.2 has it been reported that the canBus adapter sends the proper reverse trigger signal
for a 997.1 - you will get the reverse trigger via
1) tapping into the black + blue wire from the taillight harness (this is easy to do if you already have the reverse camera cable fished from the rear - MAKE SURE YOU DO NOT USE THE 2-in-1 CABLE. use the 2 separate cables so you have the OPTION to have the camera turn on via standard 'putting it in reverse' while also being able to control the reverse camera via the fCam app. the 2-in-1 cable wont allow you to do this - but it wont be a deal breaker for some
2) you can get the same black + blue cable from the kickpanel - in the first thick loom that goes to the rear of the car. pls note that in some 2005s (such as mine) - you cant find this black/blue cable here DESPITE the oem wiring schematics. my car has this issue, but 07+ does not - you can easily find the black/blue reverse trigger here (maybe 06 owners can chime in)
MAKE SURE 'prohibit reverse' is set PROPERLY in the secret android menu - otherwise hte reverse trigger will NEVER activate
Hi Pedro,
Old 08-13-2022, 12:33 PM
  #566
myw
myw's Avatar
Default something new is coming.
while not yet finished 100%
this should be the android pcm that 997/987 owners have been looking + waiting for
- fonts resemble oem (similar to the ones used in the newer climate control switches)
- ***** + buttons - with oem design in mind
- 7 PROGRAMMABLE buttons (vs 6) + sd card slot
- buttons are laid out based on oem order + functionality
- overall mold size of the unit is same as oem, doesn't protrude at the sides as the other android unit with ***** + buttons
- made + sold by owTowsin, who almost all of us bought their earlier no-buttons g1 android unit from 2020-2021in this giant thread
- silver version will use nissan kr2 paint code (a rennlist favorite - should be a good match)
- eta q4 2022 , MAYBE q3 2022 - still tweaking one thing.
Pedro Lopes (08-19-2022)
Old 08-13-2022, 05:16 PM
  #567
CRD
CRD's Avatar
Very nice! What Android version and any ideas of the cost?
iamuwere (08-17-2022)
Old 08-14-2022, 11:59 AM
  #568
myw
myw's Avatar
i will have to ask but it would have to be
- android 10 or newer
- competitive to the other pcm (with ***** + buttons in the market)
id assume whatever we were paying in 2020 for the fully loaded version (g1 - no *****/buttons) would be what this would cost for the fully loaded version (g2 - with *****+buttons)
Old 08-14-2022, 07:31 PM
  #569
faiz
faiz's Avatar
Default Anyone having issues with getting the buttons to light up?
When I turn on headlights the screen dims but the buttons don’t light up. Also notice none of the buttons seem to do anything.
it’s the latest android box (not the new one above) with **** and buttons installed in an 07 997.1
thx in advance.
Old 08-14-2022, 07:53 PM
  #570
CRD
CRD's Avatar
On my unit, the buttons light up and they work. Sounds like yours are defective or perhaps something need to be enabled on a menu.
anyone know if we can add remote buttons to this head unit? We’d need to have a wire called ‘key 1’. Perhaps on the Canbus bundle?
Quick Reply: Cheap Android Head Unit Review!
