996 Forum 1999-2005
blown engine
Old 06-19-2016, 02:52 AM
  #646
Ahsai
Ahsai's Avatar
I think I know what that piece of white plastic is.
Originally Posted by Ahsai
So I removed the fuel injectors and plan to send them out for cleaning. When I removed the cyl #1 injector, I found a small piece of chewed up plastic INSIDE the fuel rail. 1/4" x 1/"4, enough to block the injector inlet. I wonder how it got there. It wasn't introduced by me for sure as I capped off the fuel line connector as soon as I disconnected it. It's white soft plastic. Any one knows what it is and how it got there? Needless to say, I borescoped both fuel rails to make sure there is no more foreign matter.
I wonder if Cringely ever had any intermittent misfires on cyl #1
The bank 1 fuel rail end cap
The plastic in the upper part
Blown up
Out of the fuel rail. WTH it came from???
Injectors ready to be sent out for cleaning
Old 06-19-2016, 06:20 PM
  #647
ltusler
ltusler's Avatar
Make sure they flow match them too. Probably automatic for them buy it pays to check.
Old 06-19-2016, 07:19 PM
  #648
Ahsai
Ahsai's Avatar
Seems it's extra. I'll check with them. Thanks!
http://www.witchhunter.com/injectorserv1.php
Old 06-20-2016, 12:53 PM
  #649
cringely
cringely's Avatar
Not that I know of. Engine ran smooth and I didn't seem to experience hesitation on acceleration.
P.S., I am truly impressed with Ahsai's efforts. That should be one fantastic motor when finished.
Old 06-20-2016, 01:04 PM
  #650
Slakker
Slakker's Avatar
^^^ +1
Old 06-20-2016, 04:24 PM
  #651
Ahsai
Ahsai's Avatar
Hello Cringely! Was testing if you're still reading this thread
I think that piece of plastic is a piece shaved off the bottom of the previous coolant tank! The color and texture matched. Most likely someone unbolted that big hex cap on the bank 1 fuel rail to get more clearance when removing the coolant tank. When wiggling the tank out, unknowingly the opened cap bung scraped off a piece from the tank bottom and the piece fell into the rail. That explained why the piece looks like chewed up.
That piece laid right on top of the #1 injector inlet when I removed the injector. It was definitely blocking the injector flow but probably not enough to cause issues. If it had stayed deeper in the fuel rail and not visible, I would have missed it. I think I was lucky.
Old 06-20-2016, 04:34 PM
  #652
Ahsai
Ahsai's Avatar
Thanks guys. Btw, I dodged another bullet and will post soon.
Jake is absolutely right when he said we need to have a combative mind when dealing with these engines as if they were trying to kill you (your wallet).
Originally Posted by Slakker
^^^ +1
Old 06-20-2016, 07:35 PM
  #653
Noz1974
Noz1974's Avatar
So what happens at hot idle when pressure is below 1.5 bar is it just splash/ mist lubrication for the bores until revs increase and the pressure comes up ?
Old 06-20-2016, 09:16 PM
  #654
Ahsai
Ahsai's Avatar
That is correct. It's actually 1.8 bar and here's what Porsche says in the 1999 Service Info material:
"The engine has oil-spray nozzles, used for cylinder cooling to reduce the piston temperature. The injection nozzles are inserted in the bearing case. The nozzles have an opening pressure of 1.8 bar. This ensures that the engine oil pressure is retained at low engine speeds and high engine oil temperatures.
Old 06-21-2016, 07:52 AM
  #655
Oil_Slickrick
Oil_Slickrick's Avatar
Old 06-21-2016, 12:11 PM
  #656
Noz1974
Noz1974's Avatar
Thanks Ahsai!
Old 06-22-2016, 01:47 PM
  #657
Ahsai
Ahsai's Avatar
Default The other bullet I dodged!
Old 06-22-2016, 02:03 PM
  #658
p.vanderlinden
p.vanderlinden's Avatar
Cracks in the drive slot?
Old 06-22-2016, 02:27 PM
  #659
dporto
dporto's Avatar
Received 1,167 Likes on 796 Posts
^Looks like it slipped^ (look at the marks left by the original bolt positions)...Dodged a bullet indeed!!!
Old 06-22-2016, 02:31 PM
  #660
DBJoe996
DBJoe996's Avatar
Received 1,183 Likes on 757 Posts
Somebody splashed yellow paint on it?
JK....yeah, cracks in the drive slot.
^^^ oh I see that now! Slipped...good catch.
Quick Reply: blown engine
