^Thanks! You said "...replaced the whole engine with an IMSB "fix" but don't know from where..."
I think the first step is find out as much about the engine and IMSB "fix" as possible. Without knowing both, it's hard to say anything about them. There are may sources of engines. Could be a crate engine from Porsche, a used one, or a "rebuilt" one. The same goes for IMSB "fixes".
I think you have a '99 from your earlier posts and as you know '99 has its own problems like cracked head (cyl #1) so there's really no guarantee.
No one knows the true % of IMS failure. The best you can do is do all PM and as much corrective mods you could to minimize the risks. Mag drain plug and spin-on filters are always good. Also oil and filter change every 5k miles/6 months with good oil is good too.
The car (sans the engine) is in great shape and it only needs a few minor things...will see once I can drive it
Would you say the DLC is the primary reason why the Solution can survive without oil so long?
Also did you ever test the Solution without oil until it failed? I don't know if you've ever mentioned that before.
It's not just the DLC that makes the unit work. The 4 series alloy we ended up going with for the bushing material lends it's self to this application better than any other. Also there's a ton of oil in this region, and the parts stay wet with oil all the time, at start up they see oil immediately from splash as well as the delivered oil from the hose.
Yes, I did run the IMS Solution with no pressure fed oil. I'll share the pics and video later today. The unit never did fail, and the wear was not significant at all considering that it ran 1-7K RPM for 20 miles and a dyno session.
I do remember this but I just wasn't sure if you kept running it til failure.
No, but I still have the parts that were used for that test, so I probably will force it to completely fail over the summer. I did force an IMS Solution to fail early on in development. It ran 31 hours with no DLC and a non- heat treated flange, with a Ampco 45 (bronze) bushing being used. That was basically a worst case materials test, it was the first, and last time I listen to a Metallurgist during this development.
Here's the pics of the IMS Solution that I punished with no oil feed line fitted. Its been in 5 engines so far. This was 7,000 RPM over and over again, as well as lots of idle time, and 20 miles of street driving.
The wear on the flange is nil, the scratches are not measurable, nor can they be felt with your finger. The bushing also looks worse than it is, after it was cleaned up, and measured it had only .002" of wear in the worst spot. Again, this did NOT FAIL and can be cited to another engine right now, if I wanted.
That's pretty impressive. It's almost like the splash lubrication is "almost" enough to satisfy the conditions, with the oil line being there to pickup the slack as a backup. I know this isn't the case though but it seems like the oil line isn't as crucial as I originally thought in keeping this thing alive.
The oil line is critical, BUT the engine does not die immediately if the oil line is compromised. I did this for one reason, to prove that some clown that sits in his den, recording himself on YouTube couldn't be more wrong.
People like him are lost, people that listen to him are even more lost.
Jake mentioned in a 997 thread that a wrong pin offset can contribute to bore scoring. Naturally I was curious so I measured the wrist pin offset and see how much are we talking about here.
I found that the offset is toward (closer to) the exhaust side for 0.5mm ((59.54 - 58.53)/2). Since the offset should be toward the thrust side and the same piston is used for all of our cylinders, bank 1 has the correct pin offset while bank 2 has the unfavorable pin offset...just like Jake explained.
So how do Nickies and JE pistons solve this? JE pistons have no offset and their skirts are coated. Also, the cylinder to piston clearance was chosen such that it doesn't cause issues in cold weather.
What, you didn't believe me? Lol!
Told ya so... This offset only makes sense to a corporate accounting team.
Having an offset only helps if both banks have an offset that lends it's self to positive results. In this scenario we have an offset that have a correct offset on bank 1, and an *** backwards offset on bank 2.
Note how much offset we are talking here, that's a huge offset!
Couple that to an 82.8mm stroke, and the shorter rod coupled to that crankshaft, and you have accentuated mid bore wear by design, due to the steeper rod angle.
Never read about that before, huh? Never heard of that before, huh?
Sounds like Porsche engineered in certain failure - hopefully past the warrantee period...
Lol, I believe you but a pic is worth a thousand words. I've heard of it before from yourself and Charles but for some reason after the engine rebuild class my impression was there's either no or insignificant offset. Your recent posts just made me revisit this issue. I already have a clean piston lying on my bench so why not just measure it.
So obviously this is another money-saving decision. Do the Mezger engines use different pistons between the banks and have the correct offset?
That's why I love your posts Ashai. I don't discount or don't believe what Jake has to say but he hardly ever posts the pudding ( don't take that the wrong way, Jake)
you do and that is what will convince most people of the truth on these motors.
Don't think Jake will bother but I'm looking forward to a video of him leaving an opened engine block and piston in the snow overnight. Then the next morning swing a 3lb hammer at it to knock the seized piston out of the block
