#$@! Blew my engine today #&*#@!
03-04-2015, 04:01 PM
Sounds like I need to drop the sump plate during my next oil change. Have microscope to inspect!
Thanks Jake!
03-04-2015, 05:53 PM
Quote:
Originally Posted by
Flat6 Innovations
Every single car that we see, for ANY reason, has the sump pulled, filter pulled, and gets the finger test .
Jake, what's a finger test?
03-04-2015, 08:07 PM
"Jake, what's a finger test?"
Well, I'm certainly not Jake, but if I had to guess I'd say - wipe your (clean) finger around the bottom of the sump plate then rub it together with another finger on the same hand...If you feel any grit/rough stuff in there besides a smooth oily feeling, you can bet that your bearings, crank journals and anything else in your motor with tight moving tolerances can too
03-04-2015, 09:36 PM
Ok. I thought he meant like tye prostate exam reaming we get when these motors blow.
03-04-2015, 10:02 PM
I knew if I waited long enough, an intellectually stimulating conversation would be brought down to our level with an innocent "finger test"
R
03-04-2015, 10:13 PM
Cuda911
Been there done that....it's not as fun as it sounds. Trust me on this one.
03-05-2015, 11:27 AM
I took the finger test to mean sticking your finger up in the oil filter discharge port in the engine to see if there is any debris.
03-05-2015, 03:07 PM
VA951
With the multiples references to pulling the sump plate, it seems obvious it is a finger check around the sump for debris.
03-05-2015, 03:57 PM
Not obvious to me. Once you pull the sump plate you use your eyes. You cannot see up into the filter discharge port hence the finger test.
03-06-2015, 12:29 AM
Former Vendor
VA951
You got it...
And if there's any debris there, its time to say bye bye to your main and road bearings. Why? Because that debris laden oil has a one way, non-stop ticket straight to them.
If I find ANY debris in this area, I won't touch the engine.
03-06-2015, 12:35 AM
Thanks Jake for the elaboration.
03-06-2015, 09:01 AM
"Thanks Jake for the elaboration."
Indeed! It's the 996 prostate exam
03-15-2015, 03:33 PM
Jake, have you got the photos of the motor? Would be interesting to see all that destruction you described.
03-18-2015, 03:56 AM
21 pages straight through. I had to take a break.... 29 to go!
03-18-2015, 12:16 PM
Captain Obvious Super User
Cuda911
The engine is now his, if he doesn't want to post pictures then so be it, don’t push it.
