996 Forum 1999-2005
Improved Clutch Action Dramatically
Old 04-11-2007, 03:32 PM
  #106
1999Porsche911
1999Porsche911's Avatar
Originally Posted by Porsche_Smile
so it only takes around 10 mins and a plier..... am i missing anything else?
Nope, you are not missing anything, other than putting the nail in the piston first.
Old 04-11-2007, 03:34 PM
  #107
Porsche_Smile
Porsche_Smile's Avatar
thanks......... 1999porsche911
Old 04-11-2007, 03:38 PM
  #108
1999Porsche911
The only other concern with doing this mod....if you are not as young and as limber as you think you are.......make sure there is someone within calling distance to help pull you out from under the dash when the job is done.
Old 04-11-2007, 03:42 PM
  #109
Porsche_Smile
damn... i think i might have a problem then.....
Old 04-11-2007, 03:59 PM
  #110
RamVA
RamVA's Avatar
To be clear, I've done the mod and am not entirely convinced. I'm withholding judgment until after tomorrow at the track.
Old 04-11-2007, 04:13 PM
  #111
ArneeA
ArneeA's Avatar
You need a porsche 996, pliers, and 10 mins.
Old 04-11-2007, 04:18 PM
  #112
Porsche_Smile
i knew i was in trouble..... although i do have the pliers and perhaps 12 mins......
Old 04-11-2007, 07:47 PM
  #113
TAILWAG
TAILWAG's Avatar
a flathead also helps as the tab that holds the piece in place sometimes is VERY tight and you have to use the leverage of the holders (with the screwdriver) to pry it out.
I would definitely use duck tape on the end/edge of the pedals (especially if you have aluminum pedals )..trust me on this.
Old 04-12-2007, 12:30 AM
  #114
gota911
Newbies Hospitality Director
gota911's Avatar
Originally Posted by hamilton
it is a good thing you are an anonymous internet person because this would normally earn you a punch in the nuts.
Hamilton – first off, if I offended you, I apologize. I can assure you that there was absolutely no malice intended in my comment.
However, I think you over reacted to my comment. I was not trying to get away with a caustic, sarcastic remark by hiding behind a smiley icon. If you re-read your original post (quoted below), you inferred that you thought you may be a retard (your inference, not mine) because you had stalled your P-car. Then when this thread started, you had the revelation that others here had also stalled their P-cars, so you inferred that you were glad to realize that you were “not a retard.” I was just playing along with your original jab at yourself, which I thought was a very light-hearted comment. I did not call you anything that you had not called yourself. I did not attack you or call you a big, fat idiot. I was merely laughing with you, not at you.
I'm glad I'm not a retard. I have been driving manual transmission cars for the last 22 years and I kill the 911 at least once a week. I will have to give this a shot...
Originally Posted by gota911
Even if you do this mod and quit stalling your p-car, you may still be a retard!
If you have read any of my other posts, you know that I do a lot of kidding around with a lot of guys here, and none of it has EVER had any malicious intent. Since you obviously can not take a joke or any kind of kidding, I can assure you that there will be no chance of any future misunderstandings because, in the future, I will not reply to any of your posts.
Once again, I apologize if I offended you.
Old 04-12-2007, 12:58 AM
  #115
nick49
nick49's Avatar
By the way, am I the only one that threw up after doing this mod?
I did it Sunday morning after 2 cups of strong coffee. I'm lucky I hadn't eaten anything. Anyway it was challenging as being 6' 190 lbs with broad shoulders, I didn't fit under there very well. And to make matters worse, the spring thing and pivot area was at a distance where it was out of focus with or without my glasses. I had to imagine what needed to be done and fiddle around with tools by feel. I never did remove the ventilation conduit, just tried working around it. It took me longer than it should have mainly because I was working around the switch and bumped it hard enough that it came apart. I had to figure out how to put it together and it jambed up so I had to remove it and try again. All the time I'm upside down and my coffee is not wanting to go up hill to get digested. I finally got it done and wiggled out of the small confine of the work area, stood up and started...you know the rest.
Old 04-12-2007, 01:25 AM
  #116
ArneeA
ArneeA's Avatar
You should have removed the vent. It takes 2 seconds and saves alot of grief.
I also used glass frames with little LED lights on each side to light my way through.
Old 04-12-2007, 01:37 AM
  #117
itorque
itorque's Avatar
gota911- I haven't been a member long but learned early that you have a great sense of humor and I totally cracked up when I red your retard reply. Not laughing at hamilton-just laughing cause its funny.
Old 04-12-2007, 01:45 AM
  #118
jasper
jasper's Avatar
Originally Posted by nick49
...being 6' 190 lbs with broad shoulders, I didn't fit under there very well. And to make matters worse, the spring thing and pivot area was at a distance where it was out of focus with or without my glasses.....
Uh-oh - this sounds a LOT like me, except 6'0" 215 lbs and a bad neck as well.
I gotta say under dash work is my LEAST favourite kind!
Old 04-12-2007, 09:35 AM
  #119
nycebo
nycebo's Avatar
Arnee, are you serious? Did you make this yourself or buy it?
Old 04-12-2007, 10:23 AM
  #120
AndyK
AndyK's Avatar
The list of required tools should also include a barf bag I guess!? Geez. talk about giving it your all!
Under-dash work is annoying, but once I wiggle in there, I stay focused and try and get the job done the first time! Nothing worse than wiggling under your dash, only to find you forgot your screw driver!
808Bill (07-07-2019)
Quick Reply: Improved Clutch Action Dramatically
