996 Forum 1999-2005
Ultimate Integrated Dry Sump UIDS v2.2
Old 01-09-2022, 08:43 PM
  #421
996clubsport
996clubsport's Avatar
Cant wait to get one to put this piece of jewelry on the new motor
Porschetech3 (01-09-2022)
Old 01-09-2022, 08:51 PM
  #422
Porschetech3
Porschetech3's Avatar
Received 4,716 Likes on 2,128 Posts
Originally Posted by Mike Murphy
So is this plate a solid piece of aluminum and then the machine removes metal that is not needed?
Yes, it starts as a solid block of Billet Aluminum, Then uses the reduction manufacturing process to CNC away undesirable material to only leave what's desired.
Originally Posted by zbomb
Awesome Skip... Looks like it has the O ring groove as well... Really is a beautiful looking part.
Yep, the o-ring grove is there, plus the threaded boss for the AIM oil temp Sensor (M10x1.0) if used, or will come plugged off. The capacity was increased another .5qts by using a sunken floor and recessing the Twin Tunnel Ports without loosing any ground clearance, and a few other little details went into the production model.George is a Master at the details !!!
The following 5 users liked this post by Porschetech3:
frederickcook87 (01-16-2022), Kris Murphy (01-09-2022), Mike Murphy (01-09-2022), plpete84 (01-10-2022), zbomb (01-09-2022)
Old 01-09-2022, 08:56 PM
  #423
Hal
Hal's Avatar
I haven’t checked in for several weeks. Will the initial sump fit a 3.4 Cayman?
Old 01-09-2022, 09:33 PM
  #424
Porschetech3
The production models for Boxster/Cayman will be rolled out at the same time as the 996/997.1 model.
There is a different version for Boxster/Cayman since the dynamics/orientation of the engine is reversed.
Old 01-10-2022, 06:29 PM
  #425
zagaone
zagaone's Avatar
Hi Skip. Where can we see the UIDS v3.? waiting list or know our spot # on it. Thanks
Old 01-11-2022, 08:07 PM
  #426
Porschetech3
I don't know what you can see on the list, but I can see it, and looks like you are #46. I wouldn't worry about where you are on the list, when George gets the CNC Machine in high gear, it can turn out 7-8 sumps a day.
I will be sending out a questionnaire shortly to everyone on the list to gather some data on the cars/engines that the UIDS will be installed on, hopefully to include a UOA.
So if you haven't yet got a UOA, I suggest you get one now.
plpete84 (01-12-2022)
Old 01-11-2022, 08:20 PM
  #427
driverx
Cruisin'
driverx's Avatar
Do you have a preferred analysis company? i just got a Blackstone report done with the last oil change.
Old 01-11-2022, 11:03 PM
  #428
Porschetech3
I prefer SpeedDiagnostix since there tests will see particles up to 10 micron, but others will do, I'm just glad you have some data..
Old 01-12-2022, 10:37 AM
  #429
plpete84
plpete84's Avatar
Received 1,842 Likes on 934 Posts
Good stuff. I have 2 UOAs with SpeeDiagnostix ready to go for you with access to manometer and Durametric to provide any additional data that it can give. Definitely like the approach taken here. Not only are you designing a product that will address a major issue but it goes beyond just selling it. I think this database of info will be very helpful for you but for also other folks learning about the product.
Old 01-12-2022, 09:59 PM
  #430
Porschetech3
Thanks Pete !!
BTW I've had several people PM me thinking they had to do an oil change to do a UOA. It is not necessary to do an oil change to get a sample.
Just warm up the oil, then shut down the engine and use one of those oil extractors to get a sample from the dip-stick tube. It wont go all the way to the bottom of the Sump because the tube is crimped on the lower end, but will down enough to get a sample.
The following 2 users liked this post by Porschetech3:
C2-996 (02-07-2022), Mike Murphy (01-12-2022)
Old 01-12-2022, 10:06 PM
  #431
GC996
GC996's Avatar
Received 3,983 Likes on 2,258 Posts
Originally Posted by Porschetech3
Thanks Pete !!
FYI, LN sells them on their website.
Porschetech3 (01-13-2022)
Old 01-13-2022, 12:39 AM
  #432
3/98 911 coupe
3/98 911 coupe's Avatar
Default It’s not worth the cost.
Thanks Pete !!
skip at worst we are talking about a $30k engine. Honestly as a lubrication engineer I don’t understand you guys Afair with a used oil analysis. Yes I had many truck fleets with Cummins signature 600 engines, yes people those are 1 million dollar engines, yes on those I can understand used oil analysis but on our engines, one I think
is overkill , two if you send them to speed diagnostics, I wouldn’t even send my lawn mower used oil analysis over there. A lot of people here don’t know what they are doing or who’s lab they are sending their samples to. Anyway if you want a true perspective next time you send a sample to wherever, ask them what equipment are they running the sample on, when it was manufactured and worst yet when was the last time it was calibrated,
Old 01-13-2022, 01:13 AM
  #433
Porschetech3
I agree I wouldn't send my lawn mower used oil there for analysis either, or anyplace else. I am probably more frugal with my money than you are. ( a lot because I have a lot less of it...lol)
But my Porsche engine, that's different. Too many M96/7 engines have debris in them/or are making debris. I understand SpeedDiagnostix can detect metal debris up to 10 microns, many can only detect up to 5 micron.
If you know of a Lab that can detect metal debris larger than 10 micron on a UOA, please let us all know, or maybe you could do the community a favor and find us one?
Old 01-13-2022, 06:41 AM
  #434
3/98 911 coupe
Default Used oil analysis lab.
I believe I have stated or mentioned this before on the community. I would use Analysts Inc here in stafford Texas. If anyone is going to do an analysis go ahead and get the Cadillac I believe it’s 21 elements and also get readings on TBN and TAN. This lab normally doesn’t do individuals but if you give them a call as I did I guess like 7 or 8 months ago they’ll work with you. Thanks
Old 01-13-2022, 10:56 AM
  #435
Porschetech3
Would you mind posting your Analysis Inc. report? Also what is the cost and do they detect debris 10 micron or over?
Definitely not going to turn this into an "oil thread".......
Quick Reply: Ultimate Integrated Dry Sump UIDS v2.2
