996 Forum 1999-2005
zbomb's confused 996
Old 01-07-2022, 10:51 AM
  #1141
Justin76
Justin76's Avatar
Originally Posted by zbomb
Well, its a turnkey product, so I'd hope so. But... for what I would want excruciatingly expensive.
Hopefully when I'm done and sorted folks can use my setup as a resource to follow (if it works )... It's not always pretty watching the sausage being made but I find the process to be part of the fun so I share the highs and the lows.
I hope it works so we can see the cost break down and compare to a turn key setup...
Old 01-08-2022, 08:44 PM
  #1142
zbomb
zbomb's Avatar
Received 4,292 Likes on 1,812 Posts
Got the hard part out of the way on the lexan door windows.
Started with cutting my window out of another sheet of home depot lexan. Came out looking pretty good so I moved on to attaching it to the door. For this, I used a total of 5 riv nuts I installed in the door frame. 3 M6 and 2 M5. I was very happy I was able to get the riv nuts in the actual door frame. Ended up not having all the hardware I needed to install, but I did have enough for mock up and this solution seems like its going to work very well. The window tucks right under the factory weather stripping which should mean that it keeps the inside relatively dry and it should be out of the wind nicely.
Door frame with riv nuts installed.
And with the window mocked up.
My final plan for mounting is to get some countersink washers from McMaster and glue them to the window and then use a phillips screw to secure. Should take under a minute to remove or reinstall.
Tomorrow I'll get the other side cut, the the black boarder painted and just be waiting on the hardware to be done.
GC996 (01-08-2022)
Old 01-08-2022, 09:04 PM
  #1143
SoCal911t
SoCal911t's Avatar
Received 1,471 Likes on 710 Posts
Looking good!
Or you could use Tinnerman aircraft washers for better streamlining.
Old 01-08-2022, 09:08 PM
  #1144
zbomb
zbomb's Avatar
Socal... I like, I actually was thinking about just drilling the countersink right into the lexan but decided to use the countersink washers in hopes they give me some purchase when removing so I don't have to touch the actual lexan... the stuff scratches if you look at if funny. Most of the time on track, the windows will be removed so, in this particular case, aero came secondary to aesthetics.
Old 01-08-2022, 09:22 PM
  #1145
SoCal911t
SoCal911t's Avatar
My streamlining comment was more tongue in cheek.
I was thinking that the Tinnerman washers have more area for glue to bond to the Lexan panels than the other style.
Old 01-09-2022, 01:19 AM
  #1146
powdrhound
powdrhound's Avatar
Received 1,882 Likes on 1,098 Posts
Hi Jason,
Since you're gutting the car and putting in a full weld in cage, you might think about removing the transverse floating crash bar that runs from one side of the car to the other across the tunnel. None of the Cup tubs have it, it's only added to the street tubs and serves no purpose once you have a cage in there. From what I recall, it's over 20lbs worth. We simply welded a piece of sheet metal over it to close it off.... Deleting the parking brake will shave a few pounds also...
Derek King (01-11-2022)
Old 01-09-2022, 03:52 AM
  #1147
De Jeeper
De Jeeper's Avatar
Received 3,432 Likes on 1,800 Posts
Im glad u mentioned that bar. He needs more encouragement as he keeps telling me no when i bring it up.
Old 01-09-2022, 08:54 AM
  #1148
zbomb
zbomb's Avatar
Thanks John - saw that while drooling over the fab work in your build - 20 LBS from the rear of the car is pretty significant.
Budget constraints on the fab side will likely mean I forgo - maybe I'll see if my buddy @De Jeeper wants to come take a winter vacation to MA and hook me up.
Old 01-09-2022, 10:49 AM
  #1149
powdrhound
powdrhound's Avatar
Understood Jason. Yeah, it’s some additional labor for sure and I didn’t know if you were doing that yourself. We essentially cut out every tab, bar, and/or support that is not present in a Cup tub. It all adds up in weight but yes, it’s additional labor for sure. Bulk of it consists of a case of beer, a harbor freight cut off wheel along with a half days time and you can make short order of this.
Old 01-09-2022, 10:55 AM
  #1150
zbomb
zbomb's Avatar
Oh, I can get the bar out... the cut off wheel and spot weld bit are good friends, it's getting sheet metal to close up the gap left by the bar put back in a semi presentable fashion that I can't do.
I have a cup chassis here, you've got me curious to take a closer look at what that area looks like on it.
Saw the updates in your thread, the blue interior looking mucho classy !
Old 01-09-2022, 11:36 AM
  #1151
powdrhound
powdrhound's Avatar
Thanks. Jason. I honestly didn't know all the nuances and the differences but Chris Cervelli was in charge of stripping all that out and he has intimate knowledge of what is (and is not) in the Cup tubs. You can see that once painted the tunnel area looks very "clean". You can also see how the parking brake area where the cables come though the tub has been "closed up" and cleaned up. The car has a ton of dust on it so you can barely see it as it's sitting at the shop body shop scheduled for 2 more coats of paint on the inside. They're just getting started. Incidentally, the sheet metal used to close up the tunnel came from the roof panel which we are swapping for a lightweight CF roof section. Talk about repurposing parts! Looking forward to seeing your project come together. Real nice job on the Lexan!
TexSquirrel (01-09-2022)
Old 01-09-2022, 11:40 AM
  #1152
zbomb
zbomb's Avatar
I love that kind of stuff.
Looking forward to seeing your project come together!
Likewise John. Thanks for the input as well, it's much appreciated.
Old 01-09-2022, 11:51 AM
  #1153
TexSquirrel
TexSquirrel's Avatar
Received 2,422 Likes on 1,287 Posts
Wow, nice cage!
I’ve been thinking about trying Lexan, but getting to the mounting inside would be tough with my bolt-in 4-point rollbar.
It looks like it would be impossible to do with your cage without using a really long extension and multiple u-joints.
Old 01-09-2022, 12:11 PM
  #1154
powdrhound
powdrhound's Avatar
Originally Posted by TexSquirrel
Wow, nice cage!
We are using an OEM RS rear Lexan window which gets glued in from the outside so not problem there. The side Lexan windows are the slotted OEM 996Cup and accessibility with that cage is easy to the side windows since the harness attachment bars are on the rear portion of the cage. Being skinny always helps with any of these cages.
Old 01-09-2022, 08:29 PM
  #1155
zbomb
zbomb's Avatar
Got the door windows wrapped up short the finish hardware I'm waiting on from McMaster. Stoked with how they came out.
The following 4 users liked this post by zbomb:
85eurocarrera (01-09-2022), lordpantsington (01-10-2022), Ratchet1025 (01-09-2022), user 8298308 (01-09-2022)
Quick Reply: zbomb's confused 996
