996 Forum 1999-2005
Installation guide of the PCCM Plus
Old 12-30-2020, 01:26 AM
  #76
KPAD
KPAD's Avatar
Thanks @e4603
Old 12-30-2020, 12:29 PM
  #77
jyoteen
jyoteen's Avatar
It's still silly to me to pay so much money without wireless carplay.
Originally Posted by mffarrell
OK, I’ll bite. How to purchase custom bat wing?
Old 12-31-2020, 02:07 PM
  #78
Celbrett
Celbrett's Avatar
That looks great! Is the interface cable long enough to reach from the batwing? can they make more?
[/QUOTE]
Birdy63 (08-23-2022)
Old 01-01-2021, 04:38 PM
  #79
victory423
victory423's Avatar
Derek and Jim at Sound in Motion, Watertown, MA have built many audio installations for me over the years. They are very creative, and most of their customers prefer that their installations look like they came from the factory.
If you want a custom batwing, give them a call for a price. I'm not sure exactly how much mine cost because it was lumped in as part of the total installation.
PBradz (09-21-2021)
Old 01-01-2021, 06:10 PM
  #80
mffarrell
mffarrell's Avatar
Thank you!
Old 01-02-2021, 11:24 AM
  #81
PAULUNM
PAULUNM's Avatar
Originally Posted by e4603
Installation on my USA 2003 996 turbo with PCM2 and MOST was very straightforward. Reused the existing GPS and FM antenna connections. Installed the new microphone; apparently the existing one is not compatible. Didn't need the FM antenna adaptor (911.645.574.55) or fiber optics MOST bridge (996.42.585.00) which are included. The kit didn't have the diversity antenna connectors and DAB receiver which are for RoW only. I put the multimedia interface box in the glove compartment, and ran a 6ft iPhone cable to the center console. I removed the really old iPod in the frunk and left the iPod adapter alone.
Sounds like you didn't need to do any re-pinning or grounding at the harness in the frunk? I too have a 2003, but with NAV and a CD changer. Hoping for a plug and play...
Old 01-04-2021, 01:19 PM
  #82
e4603
e4603's Avatar
No re-pinning/grounding for me. Per the Installation Guide section 6.5.2, it's for 97-01 cars with PCM 1 and Digital Sound package. Good luck.
Old 01-04-2021, 04:04 PM
  #83
jim010
jim010's Avatar
Another option for the USB box:
I had a thought about being able to somehow hook up a rear camera using one on the USB ports for this, but not sure if some sort of interface is needed. Maybe someone with some know how can chime in?
Old 01-04-2021, 04:46 PM
  #84
rino924
rino924's Avatar
On Suncoast it says not compatible but does anyone know if the single din unit will work in the 996? I am sure dimensions are off as well as connectors in the back.
I'd personally much rather have the single din vs the double. I am about to remove an aftermarket screen in mine and thought about putting the original radio in and relocating climate back up top and getting a GT3 delete for the bottom.
https://www.suncoastparts.com/product/SKUCLASSIC.html
Old 01-04-2021, 05:26 PM
  #85
jim010
jim010's Avatar
Maybe start a new thread on the subject
Old 01-20-2021, 10:24 PM
  #86
Celbrett
Celbrett's Avatar
I finally received the double din conversion parts and was able to get mine in, inspired by the batwing install for the multimedia box. Not as OEM looking but it works.
Old 02-05-2021, 05:32 AM
  #87
tw1s
2nd Gear
tw1s's Avatar
Hi Guys
I am facing such a problem after pccm plus installation. Menu does not open. Touch screen and keys are not active. what should I do
Old 02-05-2021, 01:37 PM
  #88
Celbrett
Celbrett's Avatar
Wow.... perhaps reset the unit by unplugging the battery and reconnecting. Aside from a bad unit, I would triple check your wiring. Maybe just have the basics plugged in to see if you can get the menus working.
It might help people to list what year car and with most (fiber) or not.
Old 02-05-2021, 04:03 PM
  #89
tw1s
2nd Gear
tw1s's Avatar
Originally Posted by tw1s
Hi Guys
https://www.youtube.com/watch?v=N8xA...9FurYi%C4%9Fit
PLS HELP ME
Old 02-06-2021, 09:55 PM
  #90
e4603
e4603's Avatar
PLS HELP ME
I believe Celbrett's suggestions are on the right path. Hard power cycle, unplug multimedia interface, attennas, MOST control unit, eject sd card/map. Also charge up the battery.
Let us know if you found a solution. Good luck!
Quick Reply: Installation guide of the PCCM Plus
