Installation guide of the PCCM Plus
So here it is..
Also printable on Google docs..
https://docs.google.com/document/d/1...3Cju5JyKo/edit
The PCCM Plus installation guide for the 996 Bose non-most system with PCM1 unit.I have the Bose analog MY2002 system (NOT MOST) in my 2002 996 Turbo.
The Bose system includes:
PCM1 unit - in the coupe
Navigation DVD unit - in the coupe
Bose 996.645.3387.00 AMP unit - in the frunk, next to the spare wheel
The PCM1 unit sends high level output to the Bose amp in the frunk.
In my case the 996.645.338.00 amp.
- The Bose amp unit takes the high level and amplify it to the speakers.
So when installing the PCCM+ I had no use of the fiber optic components included in the kit.
Here is what’s included in the kit.
Also a short youtube video - of everything
Next page..
Everything was pretty straight forward..
1: I removed dashboard bracket with the buttons for the PSM, window viper, door lock.. et.c.
- this are for the old navigation and hands free system
Next page..
7: Starting up the unit
This sorted out everything and now it works perfect.
There are several variants of this…
https://www.design911.co.uk/fu/prod1...cts2-CTTPO001/
Next page..
- start at the bottom corner with a plastic removal tool and work around it.
- This was hard to remove, but with some force it worked out.
- this is needed to install the new unit.
- The two connectors (blue and black) - which has no connections on the new unit - is for the AC and Navigation, so these will not be used again, but i just showed them in behind everything.
- new unit is only FAKRA connector for FM, DAB and GPS (I did not install the gps antenna because I will use Carplay and didn’t want to make the cable management for the gps)
- Connect ISO BLACK - Power
- Connect ISO BROWN - Speaker output
- Connect connection BLUE/GREEN/YELLOW - AMP switch on (only the yellow adapter will be used here)
- Connect all FAKRA - FM, DAB in my case (via FM/DAB unit included in kit)
Next page..
- And no sound..so here my headache started.. I got into some forums and came to conclusion that the wire (red/black) on the yellow adaptor was the one sending switch power to the AMP unit in the frunk.. but nothing happened.
So i made a bypass and gave the switch cable 12v from the 12v lighter connection to test if it worked.. And yes, we had sound.. but the gain was really high, volume *** level 1 was like half volume before and there was very high noise level in the system.
So the next day I contacted Porsche and got a tip that you have to set the
PCCM Plus unit in AMP mode if you don’t have the MOST-system
This is done if you go into the settings menu and hold the VOLUME symbol on the display for aprox 10 seconds. Now I got amp switch power without bypassing the yellow adaptor.
- but…
Still noise and high gain on the volume…
So after some research I ordered an ISO adapter with resistance for high gain to amp. This is a common problem on other cars when using after market stereo with OEM Amp - Basically this adapter takes down the output volume from the new head unit.
The following 7 users liked this post by porschebaot:
bms0918 (10-13-2020),
Frank996 (06-02-2020),
jim010 (05-17-2020),
Mikołaj (11-13-2020),
nexus77241 (10-29-2020),
and 2 others liked this post.
Super post.
Can you measure the height and width of the face of the unit and tell me what it is in mm?
I have this theory that it is a standard size used in Volkswagen and Audis of the time.
Nice write up!
In two minds about this mod as my 996 is my analogue car it does have a CDR23 + Bluetooth auto but it does look like it fits very nicely into the 996 interior
So here it is..
Next page..
Next page..
Next page..
Next page..
- but…
Nick
Looking at getting this for my 996. If I understand correctly you are not using the GPS antenna that comes with the unit but rather can access GPS data from your phone? I heard a rumour somewhere that the map data is "sold separately."
user 8298308 (06-26-2020)
