996 Forum 1999-2005
Installation guide of the PCCM Plus
Old 10-26-2020, 06:49 PM
  #61
mffarrell
mffarrell's Avatar
Originally Posted by Geckos_Rule
Turns out, I think something in the radio is draining the battery. It was consistently dying, even after 8 hours or so. I charged the battery up, unhooked it, and let it sit for two days -- and now it's fine. So, I think there's something causing some power draw from the PCCM+. Any ideas on what it might be? Or will I need to just pull it out, and try re-wiring everything in hopes that fixes it?
Are you sure it is turning off? There is a timer you can set so the unit will turn off in x number of minutes after turning off the ignition switch. Also, put an amp meter in series with the battery to see if you are getting current draw after you shut everything down.
Old 10-26-2020, 06:59 PM
  #62
Geckos_Rule
Geckos_Rule's Avatar
Interesting. I'm actually not entirely sure, but I'll take a look in the settings and see if that might be the culprit. As for the amp meter, I'll need to buy one first (which from what I've seen, is a pretty necessary thing with a 996tt)... Thanks!
Old 10-26-2020, 07:29 PM
  #63
theprf
theprf's Avatar
Received 1,777 Likes on 1,132 Posts
Another thing is that the ignition switch has a contact that's supposed to show if the key is inserted. If this contact goes bad, the car thinks the key is always inserted and won't power down completely.
You can check: turn the car on, the turn it off and leave the key in the ignition. Open the door and the screen should show "Ignition key not removed". Pull the key out and the message should go away.
Also, if you didn't re-train the windows auto up/down you might try that.
Old 11-04-2020, 07:43 PM
  #64
mffarrell
mffarrell's Avatar
Deleted.
Old 12-18-2020, 02:00 PM
  #65
jim010
jim010's Avatar
Any chance that someone has the pinout info on the plugs for the PCCM+?
Old 12-18-2020, 08:56 PM
  #66
mffarrell
mffarrell's Avatar
Wouldn’t the pin-outs be the same as a PCM2?
Old 12-19-2020, 02:39 PM
  #67
jim010
jim010's Avatar
Even so, I need the pinouts, if anyone has them
Old 12-23-2020, 03:13 PM
  #68
e4603
e4603's Avatar
Installation on my USA 2003 996 turbo with PCM2 and MOST was very straightforward. Reused the existing GPS and FM antenna connections. Installed the new microphone; apparently the existing one is not compatible. Didn't need the FM antenna adaptor (911.645.574.55) or fiber optics MOST bridge (996.42.585.00) which are included. The kit didn't have the diversity antenna connectors and DAB receiver which are for RoW only. I put the multimedia interface box in the glove compartment, and ran a 6ft iPhone cable to the center console. I removed the really old iPod in the frunk and left the iPod adapter alone.
saveferris199 (08-30-2022)
Old 12-23-2020, 04:15 PM
  #69
mffarrell
mffarrell's Avatar
Why didn’t you need the Most bridge or FM antenna adapter? Maybe you didn’t have a CD player?
Old 12-23-2020, 04:52 PM
  #70
e4603
e4603's Avatar
The FM antenna plugs right in. The existing antenna side is black, the PCCM+ side is white. The adaptor is for a 3.5mm type plug.
I don't have the factory CD player, but I have an iPod adaptor. All I did was unplug my 2004 Apple iPod.
The following 2 users liked this post by e4603:
happyelmo (02-16-2021), saveferris199 (08-30-2022)
Old 12-28-2020, 08:11 PM
  #71
victory423
victory423's Avatar
The following 6 users liked this post by victory423:
Celbrett (12-31-2020), Get Er Done (09-05-2021), lowmiler (12-28-2020), PBradz (09-21-2021), pongobaz (01-03-2021), yenismymom (01-08-2021) and 1 others liked this post. (Show less...)
Old 12-28-2020, 10:20 PM
  #72
amargari
amargari's Avatar
Originally Posted by victory423
The USB and Aux In look great!
happyelmo (02-14-2021)
Old 12-28-2020, 11:04 PM
  #73
mffarrell
mffarrell's Avatar
OK, I’ll bite. How to purchase custom bat wing?
Old 12-29-2020, 02:37 PM
  #74
e4603
e4603's Avatar
Someone asked me about the details of the unit, so here’s a page from the Operating Manual
Old 12-30-2020, 01:19 AM
  #75
e4603
e4603's Avatar
Hey Kieran, in the hidden menu, the Radio Area options are: USA (1-4), Southeast Asia, Japan, Europe, Orit, Australian, Middle East
Quick Reply: Installation guide of the PCCM Plus
