What did you do to your 996 today?
#8986
Appreciate the info!
#8987
Kit, no, just bought the sheets and used liquid nails in a tube to glue them to the door. Didn't need to seal up the sides, already pretty good. Today it was almost 100 and it was 72 in there while I was working! Also, the heat function in the winter works great also. Generally, summer I keep it at 80, winter 60. I've had that for 2 years now.
Fracture (06-18-2023)
#8988
The garage door is already insulated and I'm going to be adding insulation to the ceiling. Doing some searching, the internet recommends 9000-20,000 BTUs for a standard 2 car garage. I'm thinking 12,000ish BTUs should do it but what do I know
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#8989
I use 12,000 BTUs in my 12x12 shed/auxiliary building/detached office and I can keep temps at 68 in the high heat of the summer. For a full sized 2 car garage 12-15 is where I'd want to shake out in terms of cooling power. The mitsubishi units are super efficient. The daikin mini splits have a good reputation as well.
#8990
Do you recall what size unit (BTUs) that quote was for? I'm going to be moving a few miles inland at the end of the summer and it's enough to put me out of range of the ocean breeze I get now so I'm thinking mini split.
The garage door is already insulated and I'm going to be adding insulation to the ceiling. Doing some searching, the internet recommends 9000-20,000 BTUs for a standard 2 car garage. I'm thinking 12,000ish BTUs should do it but what do I know![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Hope that helps!
#8991
sasilverbullet (06-18-2023)
#8992
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_1695_55781eb6f21e09422d3e39c60da35776703684c3.jpeg)
Pre-swap. My Graphite Gray console was looking worse for the wear.
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_1701_76d9341de69e51c1be689a4d1db1ac39a17f9729.jpeg)
Found a black console on the ‘Bay in nice shape.
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_1702_e0dbebce0b2983650fa058ce5988e3d74682a871.jpeg)
End product. Swap was easy after watching a few YT videos. I also found some used black door pull covers to pull it together. Now the sea of gray has some nice contrast. Cheers all!
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_1704_7b9b1edb2e2ae33b1b218a48257fa542d03a5155.jpeg)
The following 11 users liked this post by jonroll:
brontosaurus (06-18-2023),
diddy2003 (07-02-2023),
EVOMMM (06-18-2023),
fazm (06-18-2023),
gtxracer (06-18-2023),
and 6 others liked this post.
#8994
The following 2 users liked this post by zbomb:
Ratchet1025 (06-27-2023),
TexSquirrel (06-19-2023)
#8995
The quote I got was for a 15k btu 1.25 ton for my standard two car garage. The AC guy said the 15k is what they put in most garages and gives you a little overhead to compensate for the general poor insulation of a garage. The quote included adding the pad for the outside unit as well as any electrical that was needed.
Hope that helps!
Hope that helps!
The following 2 users liked this post by SoCal911t:
fazm (06-18-2023),
#8996
jonroll what color is your 996? fantastic.
The following 5 users liked this post by jonroll:
brontosaurus (06-22-2023),
cwbrown (06-19-2023),
fazm (06-18-2023),
Geoff.T (06-27-2023),
JustinReinke8 (07-22-2023)
#8998
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1399/img_5253_a8356e0c6489c981607f96e75dcaadd0bbd0123b.jpeg)
The following 8 users liked this post by 85eurocarrera:
binaryaudax (06-19-2023),
EVOMMM (06-19-2023),
fazm (06-19-2023),
golock911 (06-19-2023),
and 3 others liked this post.
#9000
Always loved the Carrera graphic.. I wonder if the Cabriolet cars ever came with it?
