996 Forum 1999-2005
What did you do to your 996 today?
Old 12-14-2020, 11:01 PM
  #4411
c didy
c didy's Avatar
Originally Posted by Porschetech3
Lower the front end of the transmission down, use a 3ft long 3/8 drive extension with a short impact swivel socket !! Correct tools are the key to fast and frustration free wrenching...
3 ft extension? wow. i'm fresh out. where do you get that?
Old 12-14-2020, 11:42 PM
  #4412
AZPete
AZPete's Avatar
Here's my long extension that worked on that top bolt.
The following 2 users liked this post by AZPete:
dporto (12-15-2020), TRLBRAKER (12-15-2020)
Old 12-15-2020, 09:03 AM
  #4413
tommelton
tommelton's Avatar
Mine is from SK tools.
Old 12-15-2020, 05:27 PM
  #4414
Porschetech3
Porschetech3's Avatar
Received 4,605 Likes on 2,090 Posts
Here ya go !!
https://sktools.com/shop/36-3-8-driv...extension.html
Old 12-16-2020, 12:19 AM
  #4415
TRLBRAKER
TRLBRAKER's Avatar
I was following the Pelican book to the letter and it was only after I supported the transmission and engine and removed the front mounts I noticed there is plenty of wiggle room to slip a long-wobbly extension up there.
Although the car was built in '99, my engine was replaced under warranty in '02. 996 community wisdom suggests that I should have a single row IMSB and indeed the flange looks like a single row style. But the RMS and bolts look like the pre-update variety and I will need to figure out where to buy the updated bolts. It was nice to see zero oil leaks although the clutch friction material dropping down on me while pulling the cover plate was a bit nasty. One advantage of covid-19 is that I have plenty of masks at home.
Old 12-16-2020, 08:38 AM
  #4416
chris8382
chris8382's Avatar
Not today, but two weekends ago was finishing the install of a Gentex mirror (includes auto dim, Homelink, and compass). I know, some of you will be moaning about this not being factory-correct, but it does "fit" the interior aesthetic and seems to make more sense than sticking an additional switch on the dash for the garage door opener (and my Homelink can work multiple garage doors).
This past weekend was lubricating the SAI pump. You can still hear it, but the sound is not nearly as loud now.
TexSquirrel (12-16-2020)
Old 12-16-2020, 06:39 PM
  #4417
James_03C4S
James_03C4S's Avatar
I like the use of the Homelink & compass equipped rear view mirrors. Seems a lot safer that a garage door opener on your sunvisor that can be grabbed along with your car registration with your address on it. I used Nissan Pathfinder homelink mirror off ebay ($40) which has orange text along with a pigtail harness and rear view mirror adaptor part. Pretty easy and cheap to do.
The following 3 users liked this post by James_03C4S:
R324U (12-17-2020), TexSquirrel (12-16-2020), TheUnscented (10-05-2021)
Old 12-16-2020, 08:22 PM
  #4418
TexSquirrel
TexSquirrel's Avatar
Received 2,423 Likes on 1,288 Posts
I have no problem with that...but a LOT of my car is not factory-correct!
Great idea! Hmmm...off to check eBay before Pathfinder mirrors jump in price.
...which year(s) Pathfinder should I be looking for?
Old 12-16-2020, 08:27 PM
  #4419
TexSquirrel
I have a 20” and a 12” extension.
If the price comes out the same, having two extensions to make ~30” would be more versatile.
15 2” extensions would suck though.
Old 12-17-2020, 01:28 PM
  #4420
James_03C4S
It was from a 2016 Nissan Pathfinder. You can get a Gentex pigtail, cover (for wires), and mirror attachment adaptor pretty cheaply on thE bay.
Old 12-17-2020, 07:10 PM
  #4421
chris8382
chris8382's Avatar
Default Mirrors
Lots of manufacturers use the Gentex mirrors. You don’t need to get one from any specific car or auto brand. Mine was from a Subaru. You just need the pig tail to wire the mirror to your own car. Only takes two wires (positive and ground), so not really that hard to install. Let me know if you need advice...I learned somethings from my experience.
Old 12-17-2020, 07:16 PM
  #4422
James_03C4S
True that Gentex is used on many cars. The Subaru Gentex mirrors used a red LED for the compass. The Gentrx brand use a blur/green LED for the compass. The Nissans use an orange LED that aligns with the Porsche dash as shown in my pics.
Old 12-17-2020, 09:05 PM
  #4423
SoCal911t
SoCal911t's Avatar
Received 1,474 Likes on 712 Posts
I bought a used Gentex compass/self dimming mirror from an Audi because it uses the same windshield mount and wiring plug as a 996. The 996 harness is part # 996.612.964.00 and plugs directly into the plug on the Audi mirror. In May of 2018 it was $33.73 from Sonnen. The little window on the upper right is the compass.
Old 12-17-2020, 09:31 PM
  #4424
dporto
dporto's Avatar
Received 1,166 Likes on 796 Posts
I parked mine in the garage for "the big Noreaster"...
Old 12-18-2020, 09:21 AM
  #4425
Joel987
Joel987's Avatar
My car was sleeping soundly in the garage to the hum of the battery tender while I was clearing 20" of snow.
Quick Reply: What did you do to your 996 today?
