993 Forum 1995-1998
A Plug-and-Play, DIY-Installable 993 Immobilizer Defeat
Old 03-27-2020, 06:18 PM
  #421
tuto993
tuto993's Avatar
I noticed some pics are out of chronological order but this is something the rennlist app does every time I post pics. I think you should get the idea though...
Old 03-27-2020, 06:52 PM
  #422
Jay777
Jay777's Avatar
Above and beyond the call of duty Hector, great job , And that photography, jeeze I feel like a slackard.
Glad you like it. Enjoy!
Old 03-27-2020, 07:12 PM
  #423
tuto993
tuto993's Avatar
Any time.
Old 03-27-2020, 07:25 PM
  #424
ezinternet
ezinternet's Avatar
I was wondering how many would be interested in a version that preserved the "gong" sound, for headlights-on?
IMO I can manage without the "seatbelt disconnected" reminder ... it's not 1998 anymore, and I'm patterned to click-in.
But I'm also used to cars that turn off all the lights 30 seconds after I leave.
Any other features desired for Immo Block Gen 2?
(Just asking - unofficially)
Old 03-28-2020, 09:52 AM
  #425
Gendaw
Cruisin'
Gendaw's Avatar
Hi,
I have a US 97 C2, but live in Sweden.
If shipping is possible i would want one.
Old 03-28-2020, 10:31 AM
  #426
Jay777
Jay777's Avatar
Originally Posted by Gendaw
Hi,
PM sent
Old 03-29-2020, 02:59 PM
  #427
Lorenfb
Lorenfb's Avatar
Actually, the gong relay could be easily modified to achieve the function of the mod, and still function as a gong relay.
Old 03-29-2020, 07:12 PM
  #428
tikka308
tikka308's Avatar
Immo Block customer here - just installed it! Works well, and install was easy.
However, I had hoped the Immo Block would be the "key" to using an extra key (without needing extra key fobs), but the alarm does not seem to allow this. The Immo block has been activated, so the keyfob is no longer needed to disable the immobilizer. If I lock the door manually, then unlock it manually, the alarm goes off and the vehicle will not start. Reading the manual confirms this is expected behavior. So, even though the Immo Block works, it appears you still need a functioning key fob.
Old 03-29-2020, 08:28 PM
  #429
Jay777
Jay777's Avatar
Congrats on the install.
You’re right ... standard key/lock/alarm behavior- the Alarm Control Unit is doing that, not the IMMO. I know, crazy system. That’s why Porsche capped off the door locks and told you not to use them. Maybe we need an ACU defeat....
Old 03-29-2020, 08:31 PM
  #430
tikka308
tikka308's Avatar
What's the point of the Immo Block if you still *need* a functioning fob? Avoiding the lock/unlock is nice but falls short of what I had hoped: ensuring the car can be used if the fob is lost, damaged, etc.
Old 03-29-2020, 09:19 PM
  #431
onelove
Basic Sponsor
onelove's Avatar
Same experience and expectations I had, the device has solved my Immobilizer issue with the device, but not the alarm. My car in particular still requires me to wait a second or two prior to starting for the light to go off, likely a result of the alarm / drive block. Jays device is wonderfully designed works as expected, he walked me through this on the phone to confirm it was working, now I just need to find a way to delete the alarm.
Instagram :Swine11 | TitanMotorsports
Swine11 ReBoot - 964 / 993 Shift Boot Trim Panel
2004 996 GT3 | 1986 Carrera 3.2 (future Keen Project) | 2016 Cayenne Diesel
Old 03-29-2020, 10:21 PM
  #432
1963SWC
1963SWC's Avatar
The point for me is that I can leave my 993 unlocked in the garage for however long and then just jump in it, turn the key, and go (without having to lock/unlock to disable the immobilizer).
Also, if out on the town and unlock car with fob and then get inside and take a call or talk with someone prior to cranking it, even if this takes several minutes, I can then just turn key and crank (again without having to lock/unlock to disable the immobilizer).
The DIY block functions exactly as described. I never expected it to allow me to unlock the door with the key and not the fob as that was never described as a feature or the intent (at least I don't recall any intent for this to aid in access without a functional fob).
Now if version 2 also allowed for that, and included the chime for lights left on as well, I may have to upgrade......
The following 2 users liked this post by 1963SWC:
ed devinney (03-30-2020), Jay777 (03-30-2020)
Old 03-29-2020, 10:25 PM
  #433
mhm993
mhm993's Avatar
Track days. No need to lock the car!
Old 04-01-2020, 09:39 AM
  #434
Jay777
Jay777's Avatar
If there's enough interest in an IMMO BLOCK with a "lights-on" alarm it's pretty easy to add. It was in the original design but it turned out the long, skinny QC terminals needed for the light and door signals were not easy to come by. Solvable with a little effort if the interest is there. Could even incorporate a low voltage alarm at the same time.
ed devinney (04-01-2020)
Old 04-01-2020, 03:47 PM
  #435
DiegoR
DiegoR's Avatar
Nice mod, but how about if the remote controller doesn't lock/unlock the doors? Still can be used this device to start the engine, even if I have to open the door manually (insert key and unlock) ?
Quick Reply: A Plug-and-Play, DIY-Installable 993 Immobilizer Defeat
