Base Carrera vs Carrera S
The following 6 users liked this post by GeneTakovic:
3rdpedal (03-07-2023),
aggie57 (03-07-2023),
Denny Swift (03-07-2023),
johny221 (03-06-2023),
KLOC (04-01-2023),
and 1 others liked this post.
#198
I like the front (and maybe rear) aeromods. Can you share where you got those from?
#199
You could always recoup any power losses (and then some) due to altitude with an M-Tune for $2500 too.
#201
The following 3 users liked this post by SBAD:
#202
The following 5 users liked this post by Denny Swift:
adrianp89 (03-07-2023),
GuardsRed992 (03-07-2023),
Humbucker427 (03-09-2023),
SBAD (03-07-2023),
Staffie Guy (03-08-2023)
pkalhan (03-12-2023)
#206
He's trying to say that tunes only work at lower elevations where the air density is higher because that gives the tuner a greater range of adjustment to make more power, but I would suggest talking to an actual expert like Mitch McKee.
#207
I have a base...I don't ever think I need an S.
Basically you are set no matter which 911 you pick.
#208
M-engineering literally run their tuned cars on Pikes Peak with winning results lol.
#209
Except the engines are identical mechanically for the Carrera/S/GTS. So if one gets a pair of S/GTS turbos and a tune then one has a GTS motor.
#210
There's a track battle on youtube between a 992 Base and a 996TT. Despite the higher HP of the TT, the Base won by 4 seconds on a short course with the same driver. I haven't driven a 992, base or otherwise, but fail to understand the need for more power than the base on a road car. Most people can't handle 4000HP at the limit. If you can and you want a track car, neither the Base nor the S are ideal anyway.
