>> I meant when I lock the door either by pushing the remote one time (not holding the lock button down) or by using my finger on the door handle the windows would automatically roll up.
You'll need to push & *hold* down the remote button, not a mere click (guessing this is for safety). Yes the door handle indent will also work to close the windows - you 'hold' your finger over the lock indent on handle, but it's a bit finicky until you know the trick (like unlocking the frunk with your hand). But yes it can be programmed to work.
>> I wonder if that mod can also have the screen default to the Carplay screen when I start it. I will ask.
Mine switches to Carplay after it boots. Sounds like you have PCM 5 like me so guessing you'll have a similar experience.
That is funny. It took me forever to find out how to ENABLE rear tail lights with DRLs since they are off by default. I suppose to turn them off it's the inverse. Please check the thread I started eons ago on Coding 992 it's in there.
Yes, PIWIS is needed though I suppose (again) Launch and other analyzers may provide that options as well.
>> is there a way to disable the tail lights during daytime running lights DLR with coding? if yes what kind of exact equipment works on 992 2023.
*disable*? Usually they are already off by default in the US.. what region are you in? I used PIWIS to *enable* my rear lights during the day.
In any case you need a PIWIS setup from @rnlst_log .
I am in Canada and tail light is enabled by default. Now that I have swapped to exclusive tail lights when it's always on there's no difference between the red tail light and the smoked exclusive tail lights. That's why I want to disable it. Sorry, again where is the original post for this?
siberian
@siberian would you please post the link to the original thread? I appreciate it.
I wanted to hopefully get some insight into my problem I’m having. I took a 992 turbo s steering wheel from another forum member and put it in my 992 gt3. However the horn and buttons no longer work. Ideally I should have done by research and gutted the old one to put into the new wheel but it’s too late
anyone know what I need to do to fix it? I have access to a PIWIS
one of the error codes I try to reset is in the image below. It also says that it can’t communicate with the steering wheel. The paddles do work though
