Coding 992
#601
#603
did you replace the wheel harness, and the control box under the horn ring? I'm not sure if the steering wheel electronics unit on the wheel is different - but for sure the wiring is different. Technically, I think you only need to transfer the wiring harness from your stock wheel to the turbo wheel - if the buttons are not working, you have them plugged into the wrong spots most likely, but to be safe, I would swap out the electronics unit as well as you have it.
#604
Yes I did transplant the harness (and the entire guts of the old one) after I realized something was amiss. however I don’t know how they should be plugged in anymore. I thought they were in the right spots. Is there a reference somewhere?
#605
Let me see if I can find that info for you - or at least take a few photos of one of my wheels. The best source would be contact Stratulat Razvan @ info@protechpartseu.com - he knows everything there is to know about configuring 992 wheels. Send him a note, and I'lll also see what I can dig up . . . there is no programming to be done on the steering wheel electronic unit - only on the steering column switch unit which you didn't change.
Porschetuner2005 (06-10-2024)
#607
Hi
please teach me coding wireless carplay on PCM6.
I try to code using piwis4 ,so I look up under MIB2.but it will be not chaged...
perhaps on PCM5 change under way..Enable Wireless CarPlay in MY2019 that only came with wired CarPlay
- PIWIS 3: MIB2 (Zentralrechner) --> Manual Coding without rules --> Vehicle Configuration --> Bitfield (7) Apple_DIO_Wireless: On and Bitfield (5) wlan_5ghz_switch: On
but on PCM6 I can't change it...
please teach me way to code.
#608
Curious if anyone has been able to code the simplified dashboard offered post 2020? Don't have a pic at the moment but it combines each of the two gauge sets left and right of the tach into single views per side.
#609
I would be VERY interested in this. Can you post a picture please? I have a 2021.
siberian
siberian
#612
I was hoping for reduced....but that is positively spartan.
Any chance it can be made to display oil temp, oil pres, boost pres as well as the water temp?
Losing the outside temp and time would be fine with me as well.
#613
It should be in Kombi somewhere if it's possible. I assume the display info is configurable?
siberian
siberian
#614
#615
It should be just a tweak if it's available. Good to know it's 2022MY as I don't recall seeing anything like that when I was poking around Kombi
siberian
siberian
