Coding 992
#436
8JU Retrofit Instruction
Snow Chains-Installation Instructions
Sports Exhaust System - Silver (0P8)/Black (0P9) Retrofit
Complaint - Warning Message "Vehicle Lighting Fault" Appears in the Instrument Cluster: Observe Specified Procedure (161/20)
The Message “Enabling was performed” Appears Repeatedly on the PCM Screen: Restore Gateway (14/22)
PORSCHE Dashcam 911- Retrofit
windscar911 (07-10-2024)
#437
hello, how did you solve them by mistake? I deleted them, does anyone know how I can reactivate their driving modes, I'm only left with the individual panamera 971 turbo hybrid
#438
hello, how did you solve them by mistake. I deleted them, does anyone know how I can reactivate their driving modes
#439
#440
Spoiler
Enable Comfort Access Open / close windows & sunroof with long press on keyfob
BCM2_MLBevo_HellaConti_PO_015
Kodierwert: Bitfield (2) comfort_operation_radio_remote_control Active
Kodierwert: Bitfield (2) comfort_operation Active
Personalized_settings_vehicle: Bitfield Comfort_opening_sun_roof on
Personalized_settings_vehicle: Bitfield Comfort_opening_windows_driver_side on
Personalized_settings_vehicle: Bitfield Comfort_opening_windows_passenger_side on
Video courtesy of @jlegelis
https://mega.nz/embed/8dQjnbQQ#RG7K2...KmC6l7JeqZK0bY
First I would like to extend a huge KUDOS to @718socal and @rnlst_log for helping me in this programing.
Recently I become a Piwis 3 owner thanks to @rnlst_log BTW best costumer service available!
We start coding for comfort especifically opening and closing windows and sunroof using receiver on the Key.
I follow indications in this treat: https://rennlist.com/forums/992/1206...l#post18403123
But it did not work, so we start to play around and discover that in some cases we will need to go further to code also the account related to the keys (BIG KUDOS to @718socal he is highly knowledgeable in the matter Got to him thru @rnlst_log); at the beginning we assume wrongly that 9Y0 and 971 and 992 will be the same to activate this feature; but it was not. For some reason in my 9Y0 (Base) comfort opening an closing was not activated in the account in my case account number 1 (there were a total of 8 accounts in my 9Y0).
We found out that beside the above steps we also need it to get into Account 1 and activate comfort for each single feature as follow:
BCM2_MLBevo_HellaConti_PO_O16
Personalized_settings_user_account_1: BitfieldComfort_opening_sun _roof ---> ON
Personalized _settings_user_account_1: BitfieldComfort_opening_windows_rear_passenger_side ---> ON
Personalized_settings_user_account_1: BitfieldComfort_opening_windows_rear_driver_side ---> ON
Personalized_settings_user_account_1: BitfieldComfort_opening_windows_rear_passenger_side ----> ON
Personalized_settings_user_account_1: BitfieldComfort_opening_windows_driver_side ------> ON
After each one was code and each one was saved I disconnect Piwis and turn off and on car and everything worked.
So in a nut shell, activation on 9Y0 went as follows:
BCM2
Personalized_settings_vehicle: Bitfield Comfort_opening_windows_rear_driver_side on
Personalized_settings_vehicle: Bitfield Comfort_opening_windows_rear_passenger_side on
ALSO
Personalized_settings_user_account_1: BitfieldComfort_opening_windows_passenger_side ----> ON
Thanks again @rnlst_log and @718socal for the impeccable service if anyone here is thinking on Piwis 3 this are your GO TO! eyes closed!
#441
Can I code the seatbelt warning chime away? That’s all I want. Mine has issues and the dealer can’t figure it out.
#442
Yes and that's why we're here, what's the problem(s)?
Please do a search on the 992 Forum and you'll find it. GL
siberian
siberian
#443
I have the lightweight package, and the mirrors don't auto-dip in reverse. I think that's related to not having memory seats. Is that something that could be coded to work?
#444
Correct, they are linked. Do you have folding mirrors? You might try poking around VOF (for car config) and BCM2, driver and passenger door.
siberian
siberian
#445
Hi guys, so im trying to find a way to change the region in my 992 gts. Can anybody advise me if I can do it in PIWIS.
Trying to change from UK to Asia.
Willing to invest in PIWIS if I can get a definitive answer.
Thanks in advance
Thanks in advance
#446
#449
OK can you be a bit vaguer please? What do you want to accomplish with this change? AFAIK, you can change region in VOF, and then? You can change your interior from leather to alcantara in VOF but that doesn't mean your seats will change which is why I ask.
siberian
siberian
#450
Kombi -> Gurtwarnung: Fond Icon Anzeigen NEIN
-> Kodierwert: Codierbyte 00 Gurtwarnung Farhrer NICH AKTIV
I can't remember if you also need to disable
Kodierwert: Codierwert 00 Gurtwarnung USA NICHT AKTIV
SAVE
HTH
siberian
The following 2 users liked this post by siberian:
Captain P (04-16-2023),
Schwarz992C4S (10-31-2023)
