Correct and in checking a couple of settings (like antenna_baseplate) I have "not installed". So short of removing the HU and running a wire out of the window , whether it's lack of a tuner or antenna, AM is INOP on 2021s alas.
Thanx for checking John.
siberian
Change to installed.
And check on Mme Macan with regards to antenna, is it installed or not instslled on the coding value.
I imagine it's a property of the windshield. If the windshield doesn't come with an embedded wire antenna for AM, then turning on the option wouldn't be expected to work. The idea of stringing a wire somewhere else, however, might well work, if the appropriate jack is present on the back of the PCM.
They wouldn't need FCC type approval for an AM receiver, so that's unlikely to be an issue here. It might save them some trouble in radiated-emissions testing, I suppose.
Ready to jump on the Coding bandwagon and buy a PIWIS 3. Only hold up is someone else riding shotgun with a 2022 model. Reading thru this thread, I'm hearing of coding differences between model years. Please let chime in if this is not correct but I don't see anyone coding 2022 model yet?
Wellcome to the thread.
Share your VAL or simulation file here so that we can see your possible coding value.
If youre in SoCal, you can use my 22. I especially want to code video-in-motion like Ive had on all of my prior BMW ///M cars. The PCM 6.0 plays video beautifully, but as soon as you start driving the video playback disables but the music continues to play. The video resumes once you come to a complete stop.
