Cargraphic Valve Control Unit (992 GT3 Variant)
#31
The following 3 users liked this post by Scottykenneth:
#32
Install was pretty easy. I pulled up on some wood to give me another inch in the rear to get under as far as I could. Did the job. Amazing how heavy that rear diffuser is. Left the wing on as you don’t need to remove it. Just popping some plastic off, unscrew some screws and be careful. Fitting the module I had to try a couple times by tweaking it bc when you go to put the fan back in , the fan hits the module and won’t seat properly in the holes. The HomeLink connects with the remote but I feel it does not work. Not a big deal. Takes 2 seconds with remote. Anyone has any questions hit me up. Took me about an hour all said and done.
Diablo Dude (06-06-2023)
#33
Anyone else have issues with the buttons not working?? As of today it doesn't light up at all when the button is pressed. I only used it for 500 miles or so and 2 months or less.. Hopefully it's just a dead battery.
#35
Where are you guys buying this from? The price differences are remarkable.
Vivid Racing has it for $465
https://www.vividracing.com/cargraph...154885541.html
and Flat 6 has it for $695
https://flat6motorsports.com/product...44950465216814
#36
The following 2 users liked this post by Chowster:
Brian Himmelman (01-22-2024),
Cartod (02-20-2024)
#37
I also purchased from Supreme. 👍🏼
#39
FYI: Flat 6 makes a small connecting tab that they sell for $17.95 that will hold the module in place.
No need to cut, drill, or hope that double-sided tape can withstand engine bay heat.
Attaches to the 10mm factory bolt on the oil fill neck.
Flat 6 Motorsports - Cargraphic Non-Invasive Controller Mount (992)
#40
The following 3 users liked this post by VegasGT3:
#41
Hey Guys, I ordered the non-invasive mount from Flat 6 but as luck would have it, I lost the small mounting nut in the engine bay.
So I headed down to my local hardware store and sourced a nut, lock nut, and some 1/4" washers. I took a hard plastic puddy knife and used that as my mount for the Controller.
Worked really well. Only problem is that my remotes werent syncing right away and my engine threw a CEL. In any event, I put my car back up in the air again today and re-checked all of my connections and low and behold the remotes were syncing and opening and closing the valves. I stripped one of the Torx 27 screws that mounts the undertray so I'm gonna wait till next week to reinstall it with Loctite after fresh screws arrive at the dealer. - - - Took my time and used a lot of zip-ties routing the controller cables up on top and stainless steel ties down below.
As luck would have it, the lock nut from the Flat 6 mount fell out of my engine bay onto my diffuser just as I was reinstalling it yesterday. Typical.
At least it didnt fall down into the alternator.
Initially got a CEL, but it disappeared in short order.
Big shout out to @Jbravo23 and @Scottykenneth for all of their support and helpful tips!
The following 3 users liked this post by Diablo Dude:
#42
that being said, flat6 is charging about $100 more than supreme for the turbocharged 992 models.
#43
Nice job Mike! Glad you got it all figured out and working well!
Diablo Dude (06-10-2023)
#44
Hi,
I am Anthony with 9XX Research, and we specialize in uncharted territories. If many others have tried and cannot complete something perfectly, we will finish the job. This time around, we are introducing:
Matrix LED Full Activation for 992, 718, Cayenne, Macan, Panamera $700
Matrix LED Full Activation for 992, 718, Cayenne, Macan, Panamera $500 for first 5 from Rennlist
Taycan $900 (coming in September)
Free gift for all: Comfort windows and sunroof w/Matrix LED activation
Recoding (if needed after a dealer visit) $200 for all models
9XX Research is an Official Porsche Partner, ID# DDA2197. We strictly follow Porsche protocol on equipment standards, and therefore no remote sessions will be offered for Matrix LED Activation. We will visit you during our USA touring schedule, and we are fully equipped to recover your car from damaged codes done by others.
Recovery of full function $2000
Required if erroneously programmed by a non-Porsche partner prior.
(e.g., Homelink damage by erroneous Matrix LED coding by third party other than 9XX or Porsche Service Center)
for more details on pricing
https://9xx.com/pages/9xx-experience-pricing
Please visit 9xx.com and register for our tour, so we will not miss you in the upcoming tour.
- Past history of accomplishing what others say is “Impossible”.
- CarPlay
- Spoiler
- Camera
- MagSafe charger
- Rattle Finder
No errors, No loss of any functionality.
Just great products!
Learn more about Porsche Matrix LED system here https://www.porsche.com/usa/aboutpors...
- CarPlay
- Spoiler
- Camera
- MagSafe charger
- Rattle Finder
