Thinkdiag Magic
#856
Yeah, the "manual" light press never worked well for me. I am either heavy handed, doing it wrong, or something is wrong with my window controls.
#857
#858
Martin
#859
PJK3 (08-29-2024)
#862
wkearney99 (08-27-2024)
#863
@Rumble-Bee
@joserpaq
Thank you very much.
Now I have to go back in this thread too find the step by steps to figure out how to do it.
i’m very illiterate when it comes to computers and never have coded anything.
@joserpaq
#864
@Rumble-Bee
@joserpaq
@joserpaq
Look at screenshot of spreadsheet there.
#866
@Rumble-Bee
@joserpaq
@joserpaq
Also, the flash programming like this requires added wattage to do the writing. DO NOT do this with just your battery, or a simple trickle charger. If the system loses power in the middle of a flash you may end up bricking the module(s). An external power supply capable of 10A minimum seems to be the recommended option. Some folks have gotten away with less (or no charger) but given the towing/repair costs it's not really worth the gamble.
Z06jerry (08-27-2024)
#867
Just don't be tempted to go changing something because you "think" the name of it might mean something. There are sometimes settings that seem to conflict. There's a 718 coding PDF where most of the coding combinations are explained. Start there and work your way toward more complicated options.
PJK3 (08-29-2024)
#869
As the saying goes "There's a right way, a wrong way and the way some randoms on the Internet say they get away with."
Proceed with caution. Do not sit there in the car poking around in the menus for an extended time without something augmenting the battery.
The following 2 users liked this post by wkearney99:
Porsche_nuts (08-27-2024),
#870
The first time you use it, you can easily spend 30 minutes or more fiddling with the Thinkdiag. Gets easier the more you use it, but if you are not savvy, time moves quickly as you try to navigate the menu or use search to find things. Best attach juice to the battery to be on the safe side. It will not hurt.
tilac999 (08-28-2024)
