Thinkdiag Magic
Old 07-26-2024, 05:13 PM
  #811
Rumble-Bee
Rumble-Bee's Avatar
Originally Posted by InTgr8r
Got it sorted out....
Tried the 4 keys and still didn't work.
Also I missed needed changes for SPORT & SPORT+
Instrument Cluster: Coding value--Coding byte 0--ECO - upshift display in sport mode: [Shutdown]
Instrument Cluster: Coding value--Coding byte 0--ECO - upshift display in sport plus mode: [Shutdown]
Thanks for the update!
Does that mean you need to set the appropriate keys to shutdown AND you need to set the shutdown for the modes you want to disable the triangle for? Can you selectively disable in some mode(s) but not others? I don’t see a setting for “normal”, so I am unclear if this could be done.
I am adding this to my spreadsheet. Thanks again!
Old 07-26-2024, 05:37 PM
  #812
thesaintusa
thesaintusa's Avatar
Originally Posted by bb964
Do you have to buy the software for each car brand and maintain yearly subscription?
I haven't had it for more than a year so cannot comment on the year subscription matter.
I just downloaded the files for BMW and MB.
Old 07-26-2024, 07:53 PM
  #813
InTgr8r
InTgr8r's Avatar
I'm wondering the same thing.
I'll do some more tinkering tomorrow.
Old 07-29-2024, 12:24 PM
  #814
itbme
itbme's Avatar
has anyone figured out if there’s a way to make the USB port in the center console shut off when you turn the car off?
It stays on for about 10 minutes which is fine much as the time but I have a wireless CarPlay adapter and it forces the connection to my phone at home for a really long time after getting out which screws with other stuff
Old 07-29-2024, 12:38 PM
  #815
B Russ
B Russ's Avatar
Exactly why I returned mine and will stay wired
Old 07-29-2024, 04:53 PM
  #816
718socal
718socal's Avatar
Glad you're enjoying your PCM with MIB
Old 08-05-2024, 11:45 PM
  #817
lowbee
lowbee's Avatar
In my 718, the instrument cluster is showing the correct Asian charactors while the PCM is displaying them as square boxes. Has anyone found a setting to fix this ?
I came across a setting in ThinkDiag-2 labelled "Media Country Code" and I suspect this is where you put in the coding for Asian Characters. The default value is 0B49 and I have no idea what value to put there for Asian characters. Does anybody know ?
Old 08-05-2024, 11:52 PM
  #818
lowbee
lowbee's Avatar
I have done the MIB OEM Navigation retrofit and will be installing the LVDS cable soon.
Has anyone tried setting this to "1" to enable MAP display on the Instrument Cluster ?
Can anyone suggest other related settings that I might need to look at to get this to work properly ?
Old 08-06-2024, 12:15 AM
  #819
Irfan
Irfan's Avatar
Do we have to renew the Porsche license every 30 days?
Old 08-06-2024, 01:11 AM
  #820
thesaintusa
No.
Old 08-06-2024, 01:12 AM
  #821
ltcjmramos
ltcjmramos's Avatar
Annually
Old 08-06-2024, 01:25 AM
  #822
lowbee
lowbee's Avatar
Originally Posted by ltcjmramos
Annually
Will ThinkDiag stop working after a year or do you just get no update and the installed version still work ?
Old 08-07-2024, 12:08 PM
  #823
Irfan
Irfan's Avatar
I am not seeing online function when it's plugged in? I didn't subscribe or anything. Just installed the Porsche soft, and coded the GT3 wheel soft. Now plugged in after few weeks, but online function option is gone.
Old 08-07-2024, 12:33 PM
  #824
ltcjmramos
ltcjmramos's Avatar
I had similar problem yesterday just trying to do health check. Uninstalling and reinstalling the app fixed it
Irfan (08-07-2024)
Old 08-09-2024, 09:57 PM
  #825
skl
Official Wednesday AM Red Bull F1 test driver
skl's Avatar
I'm assuming there is not a specific version of the ThinkDiag tool for Porsches?
Quick Reply: Thinkdiag Magic
