Anyone know what this configuration does for the joker button? Found it in Thinkdiag.
Is this on a 991? I did see this config avail on my Macan and set the joker button to turn sports+ on/off but I haven't see this as an option on my 991.1
Reading this and highlighting for others. #6 above implies that this value is Hexadecimal in nature. So 10 = 16, 30 = 48, 80 = 128, and FF = 255.
80 (hex) would be the midpoint of a 00 to FF range.
To B Russ' question above about going from 10 to 12. In hex that is making a change of 1/128 of the value range (0.78% of the range). I suspect that is imperceptible.
I can't use FF it says value up to 255. Still can't write to it.
I set actual the value to 5 (not negative 5), and that results in the seat tilting back on exit and forward on door close.
Try setting it to 5 initially and see if it that works in the proper direction .. if so then try 10 ... I do not know the maximum value/range of that field.
I actually want my seatback to tilt forward on exit and backward on entry. I tried 10 and the seatback tilt back upon exit so I wanted to try -10 to get it to tilt forward. The help text says to enter a 10'S hex value so -10 is FF6 but it didn't take it. It took -10 and Thinkdiag thought it wrote successfully but the read back is 0.
I still don’t understand FF6 being -10, wouldn’t it be -A or FFF6?
Another thought is that it interprets hex value to imply negative. Maybe a simple A with no sign?
edit: I will leave that thought above, but it is not correct .. the system would not be able to diferentiate hex from Dec for values 0-9, but for diagnostic reasons you should try to enter a -9 and see what help says to do.
be brave … see if it will take 350 as the value ….
Is there a way to bleed the coolant system with this tool? I ordered one the other day but haven't been able to set it up. If so, and someone could tell me which screen to navigate to, that would be great! Thanks!
