Thinkdiag Magic
Old 09-23-2024 | 08:03 AM
  #886
F355bob's Avatar
F355bob
Originally Posted by thesaintusa
No. I tried other values but was unsuccessful.
Thanks. I'll stop trying
Old 09-23-2024 | 08:39 PM
  #887
B Russ's Avatar
B Russ
Can we do a PDK relearn with this device
Old 09-24-2024 | 12:51 PM
  #888
tehhippy's Avatar
tehhippy
Anyone peaked around to see if there's a way to set the default audio source at startup using ThinkDiag? Trying to avoid that FM blast while car waits to re-connect Bluetooth. Thanks!
itbme (09-24-2024)
Old 09-24-2024 | 03:32 PM
  #889
lowbee's Avatar
lowbee
This would be helpful. My car randomly turn on the radio once in a while even though I never have it on when shutting the car off.
itbme (09-24-2024)
Old 09-24-2024 | 03:56 PM
  #890
itbme's Avatar
itbme
That would be so good. When I still had the crappy XM trial the car would always start playing smooth jazz loudly. Now it’s blasting FM.
Sometimes you can change source to media or whatever, but a few starts later- blasting FM again.
Hell, I’d be happy to delete sources entirely from the PCM.
Old 09-24-2024 | 04:33 PM
  #891
Porsche_nuts's Avatar
Porsche_nuts
Don't know about Thinkdiag, but remember this from years ago. Reviews are mixed, some say it works, others say somebody is having a great big laugh.
Old 09-24-2024 | 04:42 PM
  #892
skl's Avatar
skl
Official Wednesday AM Red Bull F1 test driver
Interesting seeing this issue with coding a .2 compared to a .1. I definitely want to do the temp gauge "fix" on my T like a friend did with his PIWIS clone on my 981 spyder. Now I wonder if it will do the temp gauge mod on a .2. Can anyone confirm it does???
Old 09-24-2024 | 04:43 PM
  #893
Rumble-Bee's Avatar
Rumble-Bee
Keep in mind there are 2 potential pdk processes that you are referring to. The reset adaptations (Relearn in Porsche svc department parlance), and a PDK calibration. The relearn just wipes all the adaptations that have been learned based on how it has been used in the past. The calibration, on the other hand, is about a 12-15 minute process where the pdk re-calibrates shift linkage lengths and clutch engagement point, etc. all things that may change over time ... particularly clutch engagement points due to friction material loss,
@Porsche_nuts posted is a supposed call to the reset adaptations procedure ... although I cannot speak to whether it actually works,
Th re calibration, if supported in the tool, will be in the PDK module under special functions and it will be labeled as calibrate or re calibration. My launch x431 supports it .. the thinkdiag may as it is a Launch device.
I have attached a process from the service manual that is called as a predecessor to PDK calibration. It has some similarity to the process that @Porsche_nuts posted:
WM 2X00IN IMPORTANT INFORMATION ON ADAPTING THE DME CONTROL UNIT > TORQUE LOSS > ONLY NECESSARY FOR VEHICLES WITH PDK
Necessary after:
Re-programming DME control unit
Replacing DME control unit
Re-programming PDK control unit
Necessary before:
Re-calibrating PDK
Information
The accelerator pedal must always be pressed after approx. 1.5 minutes since each adaptation step is limited to 5 Nm.
How?
Engine idling:
1.1. Meet preconditions:
1. 1.1.1. Engine at operating temperature.
2. 1.2. Engine idling for 3 minutes without activating loads, press accelerator pedal once after approx. 1.5 minutes during this time.
3 1.3. Engine idling for 3 minutes with air conditioning switched on, press accelerator pedal once after approx. 1.5 minutes during this time.
4 1.4. Engine idling for 3 minutes with air conditioning switched on and transmission range engaged, press accelerator pedal once after approx. 1.5 minutes during this time.
Information
Adaptation values are deleted or stored in EEPROM when ignition is switched off after control unit run-on has ended.
This depends on the run-on period of the engine compartment purge fan.
The run-on period of the engine compartment purge fan AFTER ignition is switched off depends on the engine compartment temperature.
The run-on period is as follows at the following engine compartment temperatures:
1. < 45 °C: approx. 50 seconds
2. 45... 70 °C: approx. 200 seconds
3. > 70 °C: up to 20 minutes
5. 1.5. Switch off ignition.
Old 09-24-2024 | 04:48 PM
  #894
Got Bearings?'s Avatar
Got Bearings?
Confirmed. I did the temp fix on my .2 using Thinkdiag
Old 09-24-2024 | 04:51 PM
  #895
Porsche_nuts
This is good information and makes sense. Thanks for the delineation.
Old 09-24-2024 | 04:58 PM
  #896
itbme's Avatar
itbme
https://static.nhtsa.gov/odi/tsbs/20...43332-8620.pdf
This implies there’s a lot more to it than just the instructions there.
People did report good results just from those steps, but it could be expectation bias.
Old 09-24-2024 | 06:05 PM
  #897
bmxtreme's Avatar
bmxtreme
This is one of the main reason I ditch the stupid PCM
Old 09-24-2024 | 07:16 PM
  #898
SHooks's Avatar
SHooks
I’m going to attempt the temp reading on my 991.1 Can someone please tell me the exact way to do it on my ThinkDiag. I did go through the tread but still not sure of all the steps.
please forgive me I’m computer illiterate.
Old 09-24-2024 | 11:52 PM
  #899
skl's Avatar
skl
Thanks!
Old 09-27-2024 | 10:47 PM
  #900
bomberr17's Avatar
bomberr17
8th Gear
I see there's a "new version" and a "hot version" on AliExpress. Which one did you guys get? I don't want to get the wrong one. I have an android tablet too.
Quick Reply: Thinkdiag Magic
