Thinkdiag Magic
Old 05-16-2024, 06:39 PM
  #586
rockhouse66
rockhouse66's Avatar
Originally Posted by docskeet
This thing is great! Tonight I reset the oil service/inspection warning and changed Auto Stop/Start to remember it's last setting ie. stay off. For me, this alone was worth the price of admission.
I feel stupid asking but how did you do this? When I try to do this on my 2014 981 Cayman S, it takes me a menu of modules I can buy for $49.95...???
Old 05-16-2024, 08:02 PM
  #587
joserpaq
joserpaq's Avatar
Not sure why you are having this issue. I setup an account using my emall to login then it asked that I enter the code that came in box with thinkdiag unit and that opened up access to the modules including the service ones.
thesaintusa (05-16-2024)
Old 05-16-2024, 10:21 PM
  #588
911T4ME
911T4ME's Avatar
You get access to 2 vehicle makes also w/o paying extra. Maybe check YouTube videos for how to get started. It's really not to bad and there are some great mods available.
Old 05-16-2024, 11:55 PM
  #589
Ken718B
Ken718B's Avatar
Attached are my instructions for using the thinkdiag to code. I hope that helps.
However, are you using a thinkdiag. The first unit I purchased did not come with any modules. I bought it on amazon so I returned it. I could have bought the module but if it did not work I figured there would be no way to get my money back on the module.
File Type: pdf
911T4ME (05-17-2024)
Old 05-17-2024, 08:36 AM
  #590
rockhouse66
I should clarify. I have been able to code some things, like the accurate water temperature and teardrop wipers (took a lot of hunting for this one). But when I go to reset service it takes me to a lot of choices all listed with a $49 price tag.
Old 05-17-2024, 10:50 AM
  #591
docskeet
docskeet's Avatar
You have to download the individual “reset functions”. There was no additional charge to me with a new device.
rockhouse66 (05-17-2024)
Old 05-17-2024, 03:17 PM
  #592
Ken718B
Ken718B's Avatar
Has anyone reset any of these intervals by changing the codes in the instrument cluster?
Old 05-17-2024, 04:41 PM
  #593
911T4ME
911T4ME's Avatar
I've implemented many of these "mods" with Thinkdiag device. One was remember the last state of Start/Stop (to keep it off on each car start). Works like it should, but now selecting Sport and Sport plus modes from the sport chrono dial has issues. The sport exhaust console light comes on, but the PASM light stays off. If I then select the console PASM button (light turns on), then turn off car and turn it back on, the PASM lights is on. So in effect, the PASM setting is also remembered from the last time car was on also. Has anyone else experienced this (with auto start/stop coding) or could I have mistakenly coded PASM to remember last setting? If the later, any idea how to undo it. I'd prefer the drive mode to automatically select PASM mode.
Old 05-17-2024, 04:54 PM
  #594
Ken718B
Ken718B's Avatar
My car doesn't have PASM but I have read that the coding to remember the last mode of start stop coding also remembers the last state of PASM.
The following 2 users liked this post by Ken718B:
Curvfun (05-19-2024), Z06jerry (05-26-2024)
Old 05-17-2024, 09:37 PM
  #595
911T4ME
911T4ME's Avatar
Thanks Ken. I'll just stick with S/S as off and choose if I want PASM saved as on or off.
Old 05-18-2024, 01:49 PM
  #596
Porsche_nuts
Porsche_nuts's Avatar
Received 1,203 Likes on 725 Posts
Ok, so I set my EBD deceleration ON to 0.15 so I get flashing every time I hit the brakes. Hope the flashing alerts all the inattentive drivers and those millennials whose eyes are glued to their phones as they drive. Found an empty parking lot and took a quick vid.
The following 2 users liked this post by Porsche_nuts:
Ken718B (05-18-2024), spdracerut (05-18-2024)
Old 05-18-2024, 06:32 PM
  #597
spdracerut
spdracerut's Avatar
EBD (youtube.com)
Nice! I just went and programmed my car. My default deceleration values for on/off were 0.81 and 0.71G. I shifted those down to 0.41 and 0.31G and I used a 1 second time looking for a bit of balance of EBD during moderate braking, but not triggering all the time in slow stop and go.
Old 05-18-2024, 11:58 PM
  #598
Ken718B
Ken718B's Avatar
EBD (youtube.com)
what value did you use for deceleration off? Does it have to be lower than the on value?
Old 05-19-2024, 12:30 AM
  #599
docskeet
docskeet's Avatar
With my 2019 991.2 with *** set to remember it's last setting, the car also remembers the last PDCC setting (on or off independent of ***). Even though PDCC is off when I start the car if I select Sport + as the mode, PDCC still turns on normally.
Old 05-19-2024, 05:41 AM
  #600
Porsche_nuts
Deceleration Off is the same as pdf suggested at 0.35
The only setting changed is Deceleration On at 0.15
Ken718B (05-19-2024)
Quick Reply: Thinkdiag Magic
