Thinkdiag Magic
#333
When I first used my ThinkDiag, it performed an update, which I suspect it might do periodically. After that, it seemed to have everything it needed to perform the modifications I've done so far: recalibrating the speedometer and restoring accuracy and intelligence to the coolant temperature gauge.
IXLR8 (02-22-2024)
#334
I wonder if anyone had done a coolant flush where from what I read, the PIWIS would activate a couple of solenoid valves in the system in succession. Maybe that works as a one-way valve while bleeding the system. This thread has 22 pages; only read the first 2.
Anyway, will look at the ThinkDiag even though I have other diagnostic tools.
#335
Was your speedo that far off? I ran my GPS and compared it running a straight flat road at a steady speed. It was spot on but only to where I tested it to about 80 MPH.
I often use cruise control when not in a hurry, to stay out of ticket trouble. i figure that 5 mph or ten percent over the speed limit--whichever is greater--will keep me out of trouble. So I appreciate precision int his measure.
Of course, if the Porsche engineers had a gram of brain, they would use the car's built-in GPS to periodically calibrate the car's speedometer, thus correcting for tire wear and changes.
#336
Thanks Ken.
I tried these but no dice. I appreciate you keeping an eye out for anything that looks promising. There just may be no way to control the top on the early 991.1 from the key remote without additional hardware but the window control that does work is great to have.
#337
The Thinkdiag does not officially work on tablets and is not shown on the google play store however you may install the app manually and it should work without any issues. We can not promise it will work on a tablet but we have yet to have a customer that the app did not install on manually. To install the app manually you will need to go to the downloads section on the website.
Also, does anyone know if the thinkdiag can code using an iphone? I thought I saw somewhere that the software does work with IOS but that coding is not possible with the IOS app. Is anyone using an iphone to code?
#338
@maxblack Are you using a tablet? I think that is the reason why we can't install the app from the google play store. I saw this on the thinkdiag website. This is what it says on the website:
#339
Yes using a tablet but got it loaded, go into settings and allow non certified apps then download and install from the file listed previously, worked fine once I figured out what to do.
rockhouse66 (02-23-2024)
#340
Here is another code that I came across in front end electronics that you should check on your car. I don't think I previously sent you this one.
#341
Thanks Ken. I had tried that one but no change. I gave up and ordered smart unit. I was determined to find a way using coding but no dice.
#342
Let me know how you like the smarttop. Seeing the video of someone accessing the control module under the seat and using the vampire taps turned me off. I may do it someday if I can't figure out how to make my windows stay down after opening the top. I thought I saw that the install of the smarttop in your car is easier.
#343
I need help.
When I go into diagnostics and select systems it only shows DME. There is no front end electronics or instrument cluster options. Is there something I need to do to enable these menus?
#344
Make sure you have the correct car identified when you first connect. Then do system scan to see if it finds all your modules.
#345
I'm looking to confirm that for 982 vehicles the OverRev (OverSpeed) reports only contain 3 Ranges, and not the 6 Ranges we see on the 991/981 vehicles?
When I pull this report, either using the ThinkDiag or a Dealer PIWIS, I only see Headers listed for "Overspeed Range 1", "Overspeed Range 2", "Overspeed Range 3". I cannot find any listed for "Overspeed Range 4,5,or 6"......
Did Porsche change their report and discard the older lower Ranges of 1,2,3 and just report the older ranges of 4,5 & 6, as 1,2 & 3 in the 982/992 vehicles?
Any insight out there?
