Heat Shield Recall
#122
I'm excited to see what we get for a loaner! We dont have any experience with Porsche cars minus the one I have.
The dealer is actually letting me bring my own oil so they can do an oil change. Figured I might as well throw them a bone and have them change the oil while it's there.
#123
OK, quick question. A few of you have already noted this Air Filter. What the heck filter is this, and why is it a $132 part at places like Sunset?:
https://www.sunsetporscheparts.com/o...er-00004321007
This does not sound like the simple inexpensive ($20-ish) accordion style pre-filter in the frunk, nor the active charcoal filter ($60-ish) in the cabin under the glove box. So what is it??
https://static.nhtsa.gov/odi/tsbs/20...74885-3639.pdf
I haven't had the work done on my car yet, but mine falls within the years affected, so I suppose I'll call the dealer. I am due for a 60K service anyway... although I am not sure what goes into a 60K service. Trying to think of what I might want to ask to get done as long as the engine is exposed.
BGLeduc (06-13-2020)
#124
Received 5,413 Likes
LexVan - I stumbled across this Porsche Service Bulletin online as I was looking at this thread, and it shows exactly what goes into the work, including a diagram of where that air filter is:
Thank you, _BK, I appreciate the link you gave.
Regarding your 60K service, and assuming you have a 991.1 AND you did the 40K service (or 4 years) on-time, you may only need an oil change, and maybe a brake fluid (every 2 years) flush and the pre-filter & cabin filters (easy enough to do it yourself). The 40K is the BIG one. If you have a 991.2 the service schedule is a little different and may require more attention at 30,000 mile intervals.
#127
Do you all recommend I get that done while at the dealer for the heat shield? I've got 27k on my '16 gts. I noticed someone else did, so it got me thinking.
**after reading more about the pdk service recommendation, I think I'll skip it and do it myself when it's closer to the recommend 6/60k.
#128
macan loaner. had them replace serpentine belt and air filers...service advisor saw my overpriced accessory tire stem caps were faded and put new ones on.
#129
I just had lots of maintenance done last month, including replacing the air filters. I wonder if I can just wait till the next oil and filter change to do these two service campaigns. I doubt there was a rag left on the heat shield during the last maintenance. It is the WLC8 that I am concerned, the tank leakage diagnostic module. As the title implies, it checks if the tank is leaking gasoline?
#130
So I changed my air filters today and the filter on the right certainly looks a lot cleaner then the left, which supports the recall paperwork. Nonetheless, I was surprised that a 2-week old filter could be this dirty. The other is 4 years old.
Thoughts?
Regardless for those about to have the recall work, ask the dealer to change both even if you have to pay for the extra one.
Thoughts?
#132
Thanks for posting. I just had this done on my GT4.
#133
I wonder if air filter part no 000-043-210-07 is the same as 991-110-130-00. I just had my indi replace them and invoice shows the 991 parts number. While I don't mind that the WLC8 is replacing the air filter, I kind of find it wasteful to replace a newly installed one with another one. Maybe I'll ask the SA if I can keep my recently installed one for future use
#134
No change in sound at all to mine, with windows up or down. Why would there be any change in sound? It's just a piece they put in a gap where some service techs had stuck a rag to prevent oil from running down when filter is changed. Some caused fires.
#135
The TSB that was posted previously for the fuel sensor clearly shows how the filter is installed along with the sensor. I don't think either of these two workshop campaigns require a replacement for an engine air filter.
visitador (06-15-2020)
