View Poll Results : What model year had the problem
Other: post comment
12.66%
Did you have a coolant leak/water pump replaced?
12-19-2018 | 05:09 PM
10k miles here.
I recall while shopping for a 991.2 in April of 2017 there was a 991.2 base with 300 miles on the odo getting the water pump replaced.
01-07-2019 | 01:40 PM
2017 C4S 12.5K miles. Water pump replaced under warranty.
01-07-2019 | 01:53 PM
Last week, during my one year complimentary oil change and inspection (2018 GTS 2850 miles), the tech pointed out some coolant residue on water tube. I told him that the residue has been there since new......in either case a new water pump was installed.
01-07-2019 | 01:59 PM
New 2019 991.2 5000 mi no issues yet.
01-08-2019 | 10:48 PM
Thank you all who have responded with useful data.
01-15-2019 | 03:08 PM
Quote:
Originally Posted by
Philip Goughary
The dealership also replaced the intake "valve block" and mentioned that there is a TSB out on it.
01-15-2019 | 04:26 PM
9 month old Carrera T. I’ll pass 12,000 miles this coming weekend. No coolant leak or water pump replacement, yet, but a faulty thermostat was recently replaced.
01-15-2019 | 05:52 PM
2018 GTS , water pump being replaced at 15000 miles ( and 29 track days).
Noticed it while I was doing an oil change.
01-16-2019 | 11:10 AM
Early 2017 model (june 2016 delivery). Noticed the leak at ~2,500 miles, but no drips on floor. Progressively worse at 7,000 miles, but still no drips. No observable drop in fluid level.
01-19-2019 | 02:09 PM
Late 2017 C4S (3/2017). Replaced at 2800 miles due to squeeking noise
03-25-2019 | 07:20 PM
03-25-2019 | 08:13 PM
For those who have had the pump replaced, are dealers simply replacing it with an identical model?
03-25-2019 | 11:11 PM
kuma1416
they wouldn’t say. Presumably it is of an updated spec.
05-08-2019 | 11:49 PM
I’ve read somewhere that the 2019’s have a redesigned water pump, and that all 991’s needing pumps replaced will get the redesigned version.
05-09-2019 | 09:09 PM
TurboS_GG
I was told (by dealer) that the water pump was redesigned and was installed starting on mid-production run (?) for model year 2018.
