View Poll Results: What model year had the problem
Voters: 237. You may not vote on this poll
Did you have a coolant leak/water pump replaced?
#166
the leak seemed to stop. The pipe under the pump had streaks of dried antifreeze just like before my first pump change. I cleaned it all off and no residue for the last 400 mi. so dealer said cant do anything without evidence of leak. Still have 2 years on warranty and I check it after every drive.
#170
I just took my 2017 GTS in for its 2nd replacement pump in 15,500 miles! I asked the dealer to try to find one that could last more than 6 thousand miles this time. Good grief.
#171
It would help this Forum if you could post the part numbers of the replacement Water Pump you received and will receive.
Cheers,
Chris
#173
Water pumps are designed to not catastrophically fail right away. They develop tell tale leaks and make a tell tale grinding sound and can continue to function properly for many many many miles.
#174
Didn't read the entire thread, but my water pump was replaced in early July after it failed during a track day.
My car is a 2017 Carrera 4S, mileage was just shy of 46k km (29k miles) when the failure happened. I was aware of this possible problem and I'm glad I got to have it fixed under warranty.
That's exactly what happened to me. I noticed a leak at the end of a session, which is unusual even in the case of a coolant tank overflow. Drove the car back home and to a few places for the next few days without any issue, and then the temperature peaked to the roof. I parked the car, got it to the dealership on a flatbed and it got fixed in time for my next track day, which went flawless.
#175
Anyone know how much a water pump replacement actually costs?
#176
Whatever detail you have...
#180
It starts when impeller shaft bearing seal fails. Coolant then works its way into the bearings, dissolves the grease and weeps out the bearing vent hole. The pump at this level of failure will continue to function somewhat normally for quite a while. Over time the bearings start to break down and fail making a rattling noise. Then the shaft begins to wobble in the housing and the impeller will start to break up, that is catastrophic failure.
