Orthojoe's track build journal
#197
Hey joe great videos. Just can't get over the pace of that thing on track. Too bad about the track precision app. Seems for that option cost you're better off getting an aim dl and smarty hd and a gopro or two. Smarty with solo DL is totally mindless to use once setup. DRive and instant videos with overlay. You're right on gopro wide angle. Going to do narrow next event. Wide looks cool but makes things look very far or very close. Tow hook mount gives great sense of speed though.
On the xpel. I had shop double coat in front of rear wheels. On track that area gets thrashed on the wide body's. More than bumper. This is on my 997. I can replace just the top layer.
#198
#199
Awesome driving. We're not worthy!! We're not worthy!!
#202
Are we sure the OEM fluid is a problem? I wouldn't want to risk voiding the warranty on the braking system by using non-OEM fluid unless it's truly necessary.
#203
Hi Joe, First off, in the video with ben, it looks like he has alot of understeer in the entry.. What did you do to counter that? Is it possible to reduce the angle of the rear wing or is it fixed?
Second off, I must say that even the app is SH***, that red watch on the dash looks awesome.
I have it specced on my car now and debating if I should cancel it or not?? Kind of like the look of the watch on the dash but can't order it separately.
#204
#205
Hello everybody,
I’m from Germany. And I normally read only in this and other Forums.
I also chose the new Sport Chrono Package with the Track Precision App, so I was a little bit confused of the problems around Video that “orthojoe” had with.
Because of the Winter I had no possibility to go on a Racetrack (excited on spring), but I tested the System here on some roads around and it works fine. Video is also every time good synchronized.
At the first time I need some time to set it up, but then it is quite easy to use. I think that Porsche will care the App and extend the features. And note, that the Smartphonecams are getting better and better. I can recommend this Option.
I’m fine with it, that the Video with data were merged directly in the Phone. At Harrys Laptimer you have always to sync yourself and render it together. This needs lots of time and space on the Phone.
You can also easy record your Phonescreen with some tools, so you get one Videofile for Youtube. I read the FAQs and I found a tip/ hint for this > (2.16 How can I view my smartphone screen in large format on my PC or TV?)
For Mac I found the Software “Reflector” which uses Airplay. You only start this and connect your iPhone with usb. Now you can easily record the Screen and also the Video with Data.
It also works with HDMI and other Software…
If you search only the Videos that are recorded with the App, you have to go on iTunes. See the Point 2.11 in the FAQs ( For iOS devices, you will find the files in iTunes under "Smartphone Name" > Apps > File Sharing > Track Precision App.)
Today I had a day off, so I wanted also to make sure that the App works fine, when I go on the Track. So I made a short recording and created a Hands-on with a Demovideo.
But I had not such great ride like “orthojoe” (I’m jealous ;-)).
Here is a YouTube link for it:
@“orthojoe”: You have to try it once more. I think with your recording and video is something going wrong. (I use an iPhone 5s, and the latest V1.2.6)
Greetings from cold Germany
Racer99
Racer99
#207
LOL! Thanks for the vote of confidence, but I want to live!
Hello everybody,
Racer99
Racer99
Thanks (Harry?), I will try it once more, but I have concerns. My first session it recorded nothing. The second session it recorded out of sync, so I just gave up. Your solution to export video is viable, but I find it unacceptable. The app will be of little use to me until the non export problem is fixed.
#208
Thanks for posting! Steering wheel still looks a tad out of sync, but much better.
Hello everybody,
Racer99
Racer99
#209
Was looking at the AWE website for the wind deflector:
http://www.awe-tuning.com/awe-tuning...-wind-diffuser
In the description, it says "Allows for “single window” down driving without buffeting". That does me no good since both windows need to be down. Can anyone confirm?
#210
