Orthojoe's track build journal
#1336
having new MPSC2s put on right now. The rears felt OK but the fronts were pretty slippery, hard to turn in and pushed a lot.
any ideas what would cause that groove on the passenger rear?
driver side
passenger side
driver side
passenger side
driver side
passenger side
driver side
passenger side
#1337
Not sure what caused the groove, but your wear pattern is very similar to what my first set of cup2 were.
#1339
It is not crazy talk it is the fact that I know for sure. Obviously you need a proper driver to get those 5 seconds off.
ps: I did a lap time at Nurburgring 10 seconds faster then a factory driver (I believe it was Walter Röhrl) with bone stock 997GT3 mk2 only with race alignment and TrofeoR tires. With factory settings on Cup2s I was 6 seconds slower then Walter. If it comes to Porsche setup I know what I'm talking about.
#1340
Heat cycled out. still had tread but push was un-drivable. I had to use Tro-R cause could not get MPSC2. I like them but also liked the MPSC2. I like the Tro-R better for me. I have no back to back data comparison though and its not like my data would matter. I run Chin Red but would not consider myself a hot shoe.
#1341
#1342
one day with mooty and 5 autocrosses (2 drivers at autox, so you could call it 10)
with that in mind i am pretty happy with the wear, and now that the girlfriend has her own gt4 to race, i can probably make a set of tires last most of the season.
#1343
We put a little thicker shims in front and were able to get one more second off our previous best lap time. Now it is all maxed out -3.6 in front and -3.8 in the rear. This is the fastest possible setup for this car without modification in suspension.
#1344
Just to give you an idea how fast is GT3 991. Recently I drove Porsche GT4(factory alignment) and GT3 991 with our last version of race alignment setup. The only modification in GT3 was light weight battery. Both cars on Cup2s (GT4 had almost new Cups). GT3 lap time was 1:53, and GT4 lap time 2:01. Same driver(me) one day. 2:01 was the fastest ever lap for GT4 at this track. This day another driver(also professional driver who drove Porsche Super Cup) drove bone stock GT3 991 with factory alignment. His lap time was 1:58
What toe settings were you running? And corrected front caster?
#1345
#1346
Thanks for the info. Do you guys correct the front caster with caster pucks with the extreme front camber? If so, what caster setting do you run?
It looks like the thread length is a little dicey to get to -3.6 with spacers on stock arms... are you using an aftermarket joint with longer threads?
#1347
#1348
Fascinating. Hey Joe, you going to give these wacky cambers a try?
#1349
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,382 Likes
Fascinating indeed. I'm tempted, except that those cambers seem way too high for road use, and I drive the car to tracks that are up to 6 hours away.
Krisa9977, could you share your impressions of the car? What you like, don't like, how it compares to other cars you've driven? I don't want to derail Joe's thread, so you can post in a new thread, or in my 'impressions' thread if you prefer: https://rennlist.com/forums/991-gt3-...nifold-15.html
#1350
