Orthojoe's track build journal
#1201
Originally Posted by Ceepe
Joe and others, what are you guys running for tire pressures at the track?
MPSC2: 32F/34R hot, but others have said lower is better
I'm using Motul 300v 5w-50.
It's great. Not going back. To either Mobile1 or another weight/viscosity.
#1202
Also, Motul 300v is ester-based and does not breakdown until over 500 degrees F.
Of course, my mechanic also told me to use Motul 300v.
#1204
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,382 Likes
I hear what you're saying, but then remind myself of a few things:
1). Porsche gives the GT cars adjustable lower control arms for a reason. They don't offer it on non GT cars. If you watch the Chris Harris video on the GT4 with AP, he highlights the adjustable control arms to allow for more camber. Why would he do that and add that if factory alignment is ideal? Factory alignment is ideal for street use since it is a street car.
2). Cup cars. These guys are running -4.0 camber. The suspension between the cups and our GT3 is not drastically different
Regarding the cup cars, while many suspension components may be similar, my understanding is that cup cars run much higher spring rates, and have lower ride height and generally different suspension geometry and alignment. And using slicks likely also makes a big difference as far as optimal camber.
#1205
Yes, slicks need more negative camber, but not a difference of 3.5 degrees (-1.5 vs -4.0). One degree (-3.0- vs -4.0) would be more likely, no?
I just can't buy into -1.5 camber as being ideal for the track.
#1206
Higher spring rates would lend to needing less negative camber rather than more, no?
#1207
GT3 player par excellence
I continue to be baffled by the varying experiences and opinions of credible people regarding the camber. My own approach has been to keep the car as close to factory setup as possible, and since there are some reports of that working well for the track, I'm thinking that trying the 1.5 cambers may be worth a shot. Plus, as noted previously, the Sport Cup 2 tires have different compounds across the width, so optimum grip may mean more wear towards the outside shoulder (ie, contact patch may be good across the width, but faster wear of softer rubber may make it look like more camber is needed).
track it.
use pyrometer measure across tread, based on reading, adj camber.
while each tire and suspension system may have some preference of camber, it also depends on how u drive.
#1208
Good idea on tire temps, though I wonder if different compounds across the width might heat up differently?
#1209
Orthojoe,
Could you do me a favor and post the part numbers of the stock brake pads?
Also FWIW the GT4 alignment calls for -1.5 degree camber at all corners.
Regards,
Rob
Regards,
Rob
#1210
Basic Sponsor
Rob
front stock p/n 99135194781
rear stock p/n 99135294880
pfc front p/n 7721.11.17.44 - http://www.apexperformance.net/prod-2559.htm
pfc rear p/n 7727.11.18.44 -http://www.apexperformance.net/prod-2558.htm
ferodo front p/n fcp4464w - http://www.apexperformance.net/prod-2768.htm
ferodo rear p/n fcp4465w - http://www.apexperformance.net/prod-2769.htm
hope this helps.
Clark
hope this helps.
Clark
Clark
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: chamerly@apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist-10 on your next order or mention Rennlist during your phone order.
PCA Club Racing - National Sponsor
Clark
ApexPerformance.net
#1212
i was able to get the video and data out of the app with a mac app called reflector2 ($15) and you can all see how crappy the data recording and sound are....lots of chop and loss of signal for a second or two. The complete loss and gap at the end of each lap is horrible. How can Porsche put something like this out? Any word on a fix?
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
#1213
Another. I must say you dont hear the sound breaking up on the app itself but the lock up of the data happens at least twice a lap for 1-2 seconds.
#1214
1. if u mean a single tire with diff compound inside to outside, then look for manufacturer's guidance of temp range.
2 if u mean michelin compound is different than pirelli for example, you are right and they will heat up differently. and depending how **** you are, it will change car set up. most race cars are aligned to run a specific tire of a specific size. for example, the car on my avatar runs on yoko advan slicks. and that's what i run exclusively. never on nitto or michelin slicks. b/c the camber setup changes a lot as i change rubber.
but tire temp will really help you dial it in.
hope this helps.
if you really wnat to be picking, bring a tech.
as you come off track, the take temp and change alignent on the spot. that's how my alignment was determined
#1215
I think the iphone track app functions similarly to Harry's lap timer. You'll need an external GPS to get better data. vbox sport, maybe?
Porsche Track Precision App - YouTube
