991 GT3, GT3RS, GT2RS and 911R 2012-2019
Orthojoe's track build journal
Old 03-31-2015, 01:31 AM
  #646
MayorAdamWest
MayorAdamWest's Avatar
Has anyone tried changing the tilt of the LWBs? I find that with my helmet on, they push my head forward a bit too much, which brings my shoulders off the back of the seat. Also, I just wish they were tilted back a little more for general use.
Old 03-31-2015, 01:53 AM
  #647
rockitman
rockitman's Avatar
You would need to drill new holes at the desired tilt angle on the existing seat pan side plates...then tilt the seat and bolt through the new holes....just like Brey krause did for the 996 gt3 buckets.
Old 03-31-2015, 08:46 AM
  #648
Manifold
Manifold's Avatar
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,269 Likes on 2,436 Posts
I have the same issue, I need a few degrees more tilt.
Has the feasibility of that solution been verified for the 991 GT3?
Old 03-31-2015, 10:51 AM
  #649
Alan C.
Alan C.'s Avatar
Received 1,041 Likes on 535 Posts
If you tilt the seat the relationship of your head and shoulders with the seat should not change. The seat angle is fixed. If you want to change your line of sight then that would change through tilting the seat rearward.
Old 03-31-2015, 11:32 AM
  #650
MayorAdamWest
Yes, but gravity works in the downward direction, so the tilt back, or even to straight up and down, would help a lot. Also, as I said, I feel like it's just slightly too upright even on the street. I just want a tiny bit more tilt back.
Old 03-31-2015, 01:38 PM
  #651
rockitman
rockitman's Avatar
you need something like this...perhaps Brey-Krause will make one or you can drill additional holes for tilt with the existing seat brackets...
Old 03-31-2015, 02:17 PM
  #652
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
+1 on tilting seat rearward. Ideally the butt portion goes down in relation to under knee portion -
Old 03-31-2015, 03:15 PM
  #653
gmgracing
Basic Sponsor
gmgracing's Avatar
Originally Posted by orthojoe
Some more pictures:
1) A view with the top caliper stud installed
2) A view of the caliper back on with stud and nut
3) This view shows why 19" wheels will be a TIGHT fit, and 18" is an impossibility. The bolt for the lower control arm is already VERY close to the OEM 20" wheel barrel
4) I brought the car in to the shop for a preliminary look at possible laguna sound remedies. Obviously this won't work since it only drops dB by 3dB and I need a 9dB drop. However, we have some ideas...
Speaking of...We just devised an 'add-on' for our center sections for a customer that went to Thunderhill this past weekend. He is running our GT3 headers and center section with our sound diversion pipes that bolt on for track use, and can be flipped either direction.
DSC_1794 by GMG Racing, on Flickr
GBMA7178 by GMG Racing, on Flickr
sales@gmgracing.com
www.gmgracing.com
714.432.1582
facebook l instagram l youtube l twitter
Porsche | Audi | Ferrari | Lamborghini | McLaren
Performance Tuning | Motorsport | Factory Service
Pirelli World Challege Race Team GT/GTA/GTS/TC
Pirelli GT3 Cup Trophy USA
Porsche Motorsport — Audi Sport Customer Racing — Lamborghini Super Trofeo Series
Old 04-02-2015, 02:44 AM
  #654
orthojoe
orthojoe's Avatar
Sorry it's been a while since I've updated the thread. Things have been hectic around here lately and I've also been out of town. The work continues, though. Here's a preview of what's coming:
Old 04-03-2015, 12:13 AM
  #655
MayorAdamWest
This is my AiM setup. Does it look the same as yours?
Old 04-03-2015, 12:24 AM
  #656
MayorAdamWest
Oops, Brake Press is assigned to BRAKE_PRESS as well, but when I assigned Brake Pos to BRAKE_PRESSURE, it unassigned brake_press. Which one do you have assigned?
Old 04-03-2015, 12:36 AM
  #657
MayorAdamWest
Sorry to spam the thread, but I think I see the issue here. The SmartyCam is set to Brake Position by default, so we need to either change that, or click that checkbox at the bottom and enable all the fields, then assign brake position.
I am curious what range you have set for Brake Pressure?
Old 04-03-2015, 01:24 AM
  #658
orthojoe
orthojoe's Avatar
Yup. You got it. You have to change it to brake pressure.
On RS2, I set range from 0-1300
Old 04-03-2015, 02:12 AM
  #659
MayorAdamWest
In the smartycam manager? Psi?
Old 04-03-2015, 11:28 AM
  #660
Spyerx
Spyerx's Avatar
Received 1,781 Likes on 1,084 Posts
I fixed mooty's smartycam in his cayman over the weekend, it was defaulted to switch, changed to pressure and it started working great.
Quick Reply: Orthojoe's track build journal
