991 GT3, GT3RS, GT2RS and 911R 2012-2019
garage car lifts
Old 08-06-2016, 01:43 AM
  #31
awew911
awew911's Avatar
My 4-post is bolted. My buddy's is not and his 'walks' due to the grade in the garage floor.
Old 08-06-2016, 02:35 AM
  #32
unotaz
unotaz's Avatar
I posted this in the GT4 thread.
Go with Bendpak HD-9. I had Revolution 4 post system before and the Bendpak system is a better made system overall. The quality is superior compared to the Revolution.
I ran both power and airline straight up to my roof for a cleaner look.
The following 4 users liked this post by unotaz:
Chris murphy (05-23-2021), E30toF30 (10-30-2019), fester (01-30-2020), tjg81296 (01-19-2020)
Old 08-06-2016, 03:57 AM
  #33
farisad
farisad's Avatar
lovely setup unotaz
Old 08-06-2016, 09:35 AM
  #34
fskof
fskof's Avatar
Now that is a garage with a great collection
Great job!
Old 08-06-2016, 07:42 PM
  #35
Just in time
Just in time's Avatar
My 4 post is not bolted down. It has not moved by itself.
Old 08-06-2016, 10:43 PM
  #36
osu s2k
osu s2k's Avatar
Got it. In ohio we dont get much seismic activity. Makes sense now
Old 08-06-2016, 11:18 PM
  #37
GiuseppeM
GiuseppeM's Avatar
Originally Posted by dunlopnick
Absolutely bolted my 4 poster
I remember reading on Bendpack's website that they prefer leaving it unbolted, I don't think it was only because of seismic movements, did anyone else read that?
Old 08-07-2016, 07:43 AM
  #38
GolfTango3
GolfTango3's Avatar
My HD-9 is not bolted down and I bought the caster set with it as I have had to move it a couple times in the process of finishing the garage and will again when I stain the floor. Casters work well, but you need a couple burly dudes to push it.
I looked back in the reference materials for a recommendation one way or the other and page 26 only says that:
"BendPak lifts are supplied with installation
instructions and concrete fasteners meeting the
criteria as prescribed by the American National
Standard "Automotive Lifts - Safety Requirements for
Construction, Testing, and Validation" ANSI/ALI
ALCTV-2011. Lift buyers are responsible for any
special regional structural and/or seismic anchoring
requirements specified by any other agencies and/or
codes such as the Uniform Building Code (UBC)
and/or International Building Code (IBC)."
On page 33:
"Every 3 Months: Check anchor bolt torque. Anchors
should be torqued to 90 ft/lbs."
http://www.bendpak.com/HD-9%20VER-E-...-29-15-WEB.pdf
Old 08-07-2016, 05:39 PM
  #39
W8MM
W8MM's Avatar
I have two Revolution RFP9N000 by Rotary 4-post lifts.
They have 120 VAC hydraulic pumps to lift and need no shop air to release the locks. Just hold the interlock release lever while using the hydraulic release valve to lower in a nice, controlled fashion.
I looked at BendPak (nice lifts) but didn't have plumbed-in shop air.
http://www.garagejournal.com/forum/s...ad.php?t=30912
Old 08-07-2016, 06:24 PM
  #40
DrJupeman
DrJupeman's Avatar
Originally Posted by W8MM
I looked at BendPak (nice lifts) but didn't have plumbed-in shop air.[/URL]
Neither do I, I just use a small nail gun compressor.
Old 08-07-2016, 06:42 PM
  #41
Jpacione
Jpacione's Avatar
The HD-9 has an optional air tank that looks like a shock. Mounts under the rails so invisible. It uses the pressure from raising the lift and fills itself. As long as you use the lift somewhat regularly you don't need a compressor. I've had mine for over a year and haven't had any issues. Left the car alone for winter and didn't lose any pressure in the tank either.
Old 08-07-2016, 10:28 PM
  #42
Just in time
I also has the optional air tank installed on my BendPak HD9. So far it has worked nicely. I have noticed though that the lift has to get pretty high up so that it can build enough internal pressure. I have 10+ ft ceiling and my cars get pretty close to it, otherwise pressure stays on the low side. Never have had a problem though and have left my car there for over two weeks at a time.
Old 08-08-2016, 08:34 AM
  #43
RajDatta
RajDatta's Avatar
Interesting, will need to check this out. Is it a DIY or requires professional install?
Any chance you have further details you could share.
Thx
Old 08-08-2016, 11:49 AM
  #44
GiuseppeM
GiuseppeM's Avatar
Thx
+1, I didn't know this was an option
Old 08-08-2016, 11:52 AM
  #45
G55amg
G55amg's Avatar
Hey guys
I'm also planning on installing a lift I like the Bendpak HD 9.
I will be storing a 964 and a GT3.
I have 10'4" ceilings, do you guys think I have enough space?
Thank you
JV
Quick Reply: garage car lifts
