What did you do with your 987 today?
Old 02-15-2022, 03:32 PM
  #646
scootr
scootr's Avatar
Originally Posted by ekam
One cannot use simple metrics to compare these cars. You sit on the floor in a 308 and you simply don't need to go fast in one to get the sensation. The guy in the Camry can fall asleep with hands on the wheel, I know I can.
You probably get testosterone deficiency in the Camry...
https://www.cbc.ca/news/canada/montr...-cars-1.821146
That's funny stuff, right there
Maybe I should keep the Mustang and the Porsche.... just for my health
Old 02-16-2022, 09:33 AM
  #647
Gatornapper
Gatornapper's Avatar
Putting in new rear brake pads and sensors today.....get that silly "way-too-early" warning light off so I can get a state inspection.
The sensors on Porsche brake pads go off when there is another 5,000 miles at least left on the pads cause Porsche loves to make you buy expensive parts. Sorry Porsche. I got great Bosche pads at Pelican and $10 sensors instead of $75 ones.......my 3rd set of pad on rear.....3rd set on my fronts right now........96k miles on my sweet S.......I drive it...........
GN
Old 02-16-2022, 11:44 AM
  #648
safetyjoe
safetyjoe's Avatar
Cleaned/checked the drains and added filter screens to the roof drains.
Old 02-17-2022, 05:05 PM
  #649
jazztrip
jazztrip's Avatar
Prepping for a track day at Eagles Canyon Raceway this Saturday. New air filter and front brake pads (Ferodo DS1.11). The old pads (Ferodo DS3.12) were down to about 1mm of material left after one day at COTA and 2 days at Motorsport Ranch in Cresson TX. Looking forward to this event since I've not driven at ECR before.
Old 02-17-2022, 07:01 PM
  #650
Racer Boy
Racer Boy's Avatar
Looks like you got your money's worth on those pads!
jazztrip (02-18-2022)
Old 02-17-2022, 11:22 PM
  #651
joseph mitro
joseph mitro's Avatar
ECR is a really fun track IMO. in fact my avatar is from an event there two years ago
It's fairly technical and the surface is very smooth now that it's been repaved.
i hope to be back out there later this year.
Have fun!
Old 02-18-2022, 09:20 AM
  #652
Smudo
Smudo's Avatar
Did pick up from local dealer three sets of 997 GT3 brake air ducts that go on LCA for my 2009 Cayman.
991Targa4S (02-18-2022)
Old 02-18-2022, 09:35 AM
  #653
Gatornapper
How in the world did your brake sensors let the pads go that far? Or did you just pull them to the side?
Next time I just may put in new sensors for a few thousand miles after the old ones get to the end........
GN
Old 02-18-2022, 01:57 PM
  #654
Anthonyr105
Anthonyr105's Avatar
GN
Track Rats don't bother with sensors. They are constantly checking and wearing out pads too quick to need the car to tell them. The heat from track use can frequently set them off on new pads which just a nuisance. I take old sensors trim them down, solder the leads together and insulate to avoid lights on the dash.
Old 02-18-2022, 02:05 PM
  #655
The Duke
The Duke's Avatar
Three sets!? Are these consumables? :-)
On my vast to-do list is a note to buy one pair. Am I missing something?
Old 02-18-2022, 04:13 PM
  #656
Gatornapper
You don't know how many times I've thought of doing just that. But I thought perhaps they had a unique resistance in new ones (but never checked) so you couldn't fool the computer.
Makes total sense for those who track their cars.
GN
Old 02-18-2022, 04:51 PM
  #657
Smudo
Smudo's Avatar
Those are consumables in long term, depending on the driving conditions, but I bought two additional sets for my two friends - one has 987.1 Boxster and other 997.2 CS. These came from local dealer for 28 EUR per pair, but today I found a local I store where you supposedly can get a set for 9 EUR!
Old 02-18-2022, 06:07 PM
  #658
Racer Boy
Racer Boy's Avatar
I just take the sensor and zip-tie it to the bottom of the strut. When the time comes to sell the car, I'll re-install the sensors in the street pads.
For example: https://www.planet-9.com/threads/bra...passing.94174/
Old 02-18-2022, 07:06 PM
  #659
Schwinn
Schwinn's Avatar
Just to be clear, when people say cut the wire, the implication is the cut the wire on the brake pad, then jumper the wire there. That way, you haven't modified the car and if you decide to sell it, you can remove the jumpered wire/connector and put on street pads with the included connector easily... don't cut and jumper the car-side connector...
Old 02-18-2022, 08:24 PM
  #660
jazztrip
jazztrip's Avatar
My car doesn't have brake sensors (at this time). I use my car on the track mostly and only drive it on the road to get to/from the track. I remove the wheels and check (visually inspect, measure and record) brake wear after each track event. So I guess I'm the brake sensor. In this case, I started the last event with 5 or 6mm pad left (IIRC, my log book is not with me right now). History shows that I use 2-3 mm per track day, so I should have had more margin than what you see. It was a case of less pad = faster wear.
Quick Reply: What did you do with your 987 today?
