What did you do with your 987 today?
#226
I think we are all guilty of doing that. I think I’ll go out with mine today to watch the waves and eat ice cream. Have to take the long way to get there, lol.
#227
Tracked down squeaks and rattles in my 987.2 all week and I think *knock on wood* got 99% of them. This forum and Planet-9 has been a priceless trove of information.
Having virtually no rattles/squeaks makes the driving experience just so much better.
- white lithium grease on clutch pedal assembly for some faint squeak every time I depress the clutch.
- tighten down some slightly loose speaker screws and put felt tape on loose clips inside the passenger door.
- put foam liner around the passenger door card for some slight plastic flexing.
- taped down the AC tube on the passenger vent that has come loose inside behind the glove box.
- Loosened the rubber stoppers in the trunk hatch until it just about makes contact with the holes in the bottom of the trunk using the ink on stoppers and paper in the holes method.
#228
Can you enlighten me on the seatbelt squeak area to tighten? Beautiful car btw.
#229
https://www.planet-9.com/threads/b-p...8/#post-520913
#230
I FINALLY once and for all fixed the dreaded trunk rattle in my 2010 Cayman without tearing the entire hatch mechanism apart. Anyone that has had this issue knows it makes a car that seemingly is forged from one piece of granite sound like a 1.5 ton rattle can of spray paint. It was as simple as dialing in those 2 rubber stoppers on the hatch. Thankfully mine were nearly new and only required a few turns. FYI, you will need to turn them to the point you can barely close the rear hatch but IT WILL WORK. It feels and sounds like a new car again. Can’t wait for a long trip now. It wasn’t a deal breaker before but definitely a PITA.
#231
Got around to detailing the wheel wells on my Spyder this weekend. They were pretty nasty beforehand. While no one will probably ever notice it but me, but it’s nice knowing they’re so clean. Both front sections of the well liners were also broken, so I replaced those with brand new parts. Used the opportunity to take all the liners out and clean behind. All this ahead of having the wheels refinished this week.
#233
looks stunning!! I’ll be doing the same soon.
#235
Installed one of these to keep the winter / summer wheel tire set up and off the floor. Works pretty well...
My garage is not this clean, but you get the idea...
#239
Not in MA anymore
Springtime prep!
