What did you do with your 987 today?
#182
Finally got her out of the body shop after a new bumper, hood & windshield
#183
Succeeded installing the sprint booster for faster throttle response in the Boxa S. I'll tell you old guys right now.
Don't try this without a bottle of Aspirin nearby. That footwell is a torture box. You have to be a Hudini to get in and out of there without a scratch
Started it up, no trouble lights
Can't wait to go for a drive tonight.
#184
Pulled the left headlight to install amber LED turn signals to match the side markers. Found that the SBL LED replacement unit doesn’t fit... So I put it all back together and commenced drinking some Marzens.
#185
took the boxa S out for a short little drive to test out the Sprint Booster mod. I have to say I am impressed with the response.
Between the DSC PASM mod and this throttle response mod... this car drives like I expected it would from the factory and more.
Afterthought = it would be better if the throttle had a little exposition programmed into it. Tis would allow you to maneuver around parking situations and traffic stops easier yet still have that race ready response once on the road.
#188
- Oil and filter - Amsoil 5W40 plus factory filter, crush washer, o-ring
- Flush brakes - Pentosin Super DOT 4, Motive Power Bleeder, Foxwell to cycle ABS/PSM
- Installed Pedro’s Technobrace rear suspension brace
- Remove summer tires - 19” PS4’s
- Mount winter set - 18” Sottezero’s
Just need a nice day to treat the top, clean all drains, and maybe a last waxing before the brrrr ❄️🥶 sets in here.
Used liftbars again. Like these a lot. Very safe alternative to a full hydraulic lift.
#189
Today I shaved an extra bit of weight off the spyder.
before:
After:
I wanted this from when I bought her in 2015. Finally found the correct sticker and installed it today.
extra 5 gram in weight savings. Porsche should have done this when manufacturing the car.
before:
After:
#191
991.2 Multifunction Steering Wheel Retrofit in a 987.1
Got the GPS adapter to talk to a Paser Unican Plus to retrofit MF functionality to control aftermarket head unit in my 987.1!
#192
Looks good! I picked up my 987 Spyder with a completely de-badged rear deck. Care to provide the centering measurements for the "Spyder" emblem? I have nothing to work from. TIA
#195
