Pending projects and a few q?
#258
Professor of Pending Projects
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
Car in need of some TLC...
Tasks to be done over the next two weeks:
Replacing boots for steering rack
Replacing bushings in A-arms
Replacing brake lines with 993 parts due to Big Red brake conversion.
Installing WEVO engine mounts
Inspecting shift linkage. I am getting the shifter stuck when trying to shift to 3rd or sometimes 2nd or 4th gear... you get the idea, something is wrong with the shifter that it will act up sometimes... not always... I have all the plastic bushings for that area, so as soon as I disassemble the linkage I can determine the culprit. Might be related to engine mounts as well... we will see...
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
#260
Burgled
........................Inspecting shift linkage. I am getting the shifter stuck when trying to shift to 3rd or sometimes 2nd or 4th gear... you get the idea, something is wrong with the shifter that it will act up sometimes... not always... I have all the plastic bushings for that area, so as soon as I disassemble the linkage I can determine the culprit. Might be related to engine mounts as well... we will see...
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#261
Now, his was a C2, I have extra stuff in there since mine is a C4...
https://rennlist.com/forums/964-foru...e-bushing.html
I should stay away from the computer today... working through a cold and the meds are kicking in... I feel like I am not making much sense today... back to bed.
#262
Burgled
I did the one on Chet's car. When we ordered the parts for his car I also ordered a spare set for mine just in case I had to do the same for my car. Once the cover under the linkage is off there is easy access to all the components. This is right under the shifter.
Good luck with the cold!
#267
Now I'm waiting for my car, I want to see it White.
And I have to order the top, I don't know if buy the 993 style or the original 964.
To I have to replace the spark plugs and a bearing, and at the end of summer, oil and filters!
Regards!
Regards!
#268
With all that you have done, my preference would be a 993-styled top... but really, it has to be what YOU like.
#269
Removed muffler while I wait for the mounts...
![](http://forums.rennlist.com/upload/dsc02974sm.jpg)
Installed the straight pipes just for kicks...![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
![](http://forums.rennlist.com/upload/dsc02984sm.jpg)
I am guessing that removal of the engine carrier is fairly easy?? Did not see any diy in the forum...
#270
Looks awesome Wachuko. My WEVO mount pillow replacements have arrived today and this time I'll torque the M12 to just 55Nm. I'll let you know how it is as I am a cab guy too.
Just a quick question. I remember you used to have cat bypass and g pipe setup. I have a cat bypass now and it sounds great, and I want to try the Gpipe but I don't want it to get MUCH louder since its already pretty good. Any advice, like was it ok to drive long distances with that exhaust setup and the cab roof up? TIA
