VW/Audi 07K (2.5L 20V I5) Swap Thread
#226
- Single mass flywheel made for the 07K: https://www.fourseasontuning.com/252...etle-w-25.html
- SPEC Stage 3+ pressure plate made for the 07K
- SPEC Stage 3+ clutch disk made for the 944 NA
- Hydraulic throw out bearing from GM LS1
#227
Seen this? *assume i5 uses same bh as 1.8
http://www.rwdmotorsport.com/vw-audi...llhousing.html
...or, how far off is a regular 944 bellhousing from some holes on the vw engine
#228
I am in for a bellhousing.
I bet Issam Abed would also be in one, he's been working some development himself. I can direct group buy info his way.
#229
Rainman
Does the 1.8T use the same BH pattern at the I5?
a lot of interest lately around the web for 944 1.8 swaps, especially since MWR only builds wall posters.
if viable i think youd get a lot more than 5 orders.
#232
I think Alex previously stated that the 07K and 1.8T share a few bellhousing hole locations. But, no it's not the same bellhousing pattern
*EDIT* see Alex's post below... looks like an 07K bellhousing will work for the 1.8T, but not necessarily the other way around due to the 07K cam chain housing. In any case, it looks like this is a good idea to advertise to the 944 1.8T / MWR crowd, so thanks!
#233
The unique issue with the 07K from the 1.8T is the cam chain housing on the back of the 07K, this causes interference with regular longitudinal Audi dual-patter bellhousings (found on the 01A/01E; they have both 4cyl/07k and early I5 patterns on them). You have to trim the top two bolts off the the standard bellhousing to clear the 07K.
Since the 1.8T doesn't have the cam chain housing on the back of the motor, a simple adapter plate to the 944 bellhousing works fine (that's how MWR and many others have done it; cheaper solution than a full bellhousing). The 944 bellhousing interferes with the cam chain housing on the 07K, thus the need for a full replacement bellhousing.
In other words, I don't think 1.8T swappers will want to spend the extra money on a full bellhousing when they could design an adapter plate for a fraction of the price.
Another idea is to trim part of the 944 bellhousing to clear the 07K cam chain housing and then make an adapter plate...but you'd lose at least one of the 944 mounting bolts and there aren't many more left.
#234
Is anyone interested in a group buy on a custom designed Quick Time bellhousing? With 5 people, they would be around $1000 each, which is less than what the RM-4082 sells for online. The custom bellhousing will directly mate the 07K to the 944 torque tube, and hold the OE vw starter in a location similar to a 944.
#235
Couple other things:
Follow Jim Green on Facebook for 07k stuff. He's posting some good updates on upgrades with his 07k powered Audi 90. He's currently swapping in TT-RS cams and adding VVT to the exhaust cam (since non-turbo 07K only has it on the intake).
It would be nice to engineer the bellhousing to not require modification like the 01A/01E bellhousings do (basically removal of the very top two bolts).
Modded:
Not-modded:
Timing cover modification if running the Audi starter location:
Facebook Post
Modded:
Not-modded:
#236
https://www.facebook.com/vomit.comet.9
Modded:
Not-modded:
Modded:
Not-modded:
#237
Fantastic, that gives us 5 total. I'll also try to get in touch with some 1.8T swap guys and see if there is interest. I'll reach out to MWR, of course, but if anyone has any other contacts, please forward to me.
#239
944 disk is 225 mm
07K disk is 9" or 228 mm
#240
MWR co-owner called me back yesterday. Very nice conversation, but they feel they are in good shape with their existing bellhousing design. I'll plug ahead with Quick Time for the 07K application, but if anyone finds any non-MWR 1.8T swap in progress, let me know.
