VW/Audi 07K (2.5L 20V I5) Swap Thread
#2046
I'll make a simple block off plate for the waste gate port and send it until I go turbo.
#2048
The stock manifold actually has 2 heat shield iterations, the first is the aluminum one spot welded in place, the one seen in the picture is a steel casing that has been seam welded around the 5 runners, and they all collect laterally. I chopped mine apart good while trying to get it off
#2049
quick measurement request - what is the height from the ground to the top of the valve cover (or whatever the highest point is) measured at the front of the engine?
and what is your ground clearance to bottom of oil pan?
#2050
What are you trying to figure out? The oil cap is the closest thing to the hood. The oil pan is above the bottom of the crossmember
#2051
Want to know clearance to the hood at the front of the 07K V/C.
Not concerned about the back by the firewall.
For example on a stock 944, over the length of the fuel rail, the hood rises about 2.5" front to back.
#2052
Thanks for the pics gentlemen. Hinton, would a Lambo header plumbed the other direction work, or will it hit the firewall? The V-band is nice for race work for sure.
Also, my car doesn't have power steering. Maybe I missed the belt config, but will all the drive belts work without that pulley?
Thanks again,
Patrick
Thanks again,
Patrick
#2053
Just trying to work around the 944's low hood line and using your swap and LS guys numbers for data.
V2Rocket (06-04-2020)
#2054
Thanks again,
Patrick
Thanks again,
Patrick
As for belt routing, there has to be something in place for the PS as it is a dual pulley which the crank drives and then the second side drives the rest of the acc. At come point we will be looking into a PS delete with an idler pulley. For my build I took the PS pump, pulled the vanes out so it would not pump, packed it full of grease and capped off the inlet and outlet. Worked well.
