VW/Audi 07K (2.5L 20V I5) Swap Thread
Old 02-28-2020, 11:23 AM
  #1876
hinton
hinton's Avatar
Originally Posted by senior_squishy
It looks like a wicked sweet setup. I'll be planning out my oil system tonight, any suggestions on how many feet of 10AN I should buy?
10 feet should do it
Old 02-28-2020, 06:59 PM
  #1877
hinton
hinton's Avatar
The following 2 users liked this post by hinton:
dmnted (02-28-2020), Sixline (02-29-2020)
Old 02-29-2020, 02:13 PM
  #1878
vt951
vt951's Avatar
Remember I emailed you a while back about power steering fittings for the high-pressure lines? Mainly the banjo fittings from the 1.8T PS pump and the cooler & rack.
We agreed that I would hold off on buying anything until you figured out which ones to be used, ring any bells?
Oh yeah... I remember now. Now that my engine is finally in the car I will figure it out pretty soon. Will post here what I end up doing.
Old 03-02-2020, 12:43 AM
  #1879
senior_squishy
senior_squishy's Avatar
For the thermostat housing adapter, which housing should we be looking at and which thermostat (07k or 1.8t)
Part numbers would be good, not sure what I'm supposed to be looking for.
Old 03-02-2020, 12:50 AM
  #1880
hinton
hinton's Avatar
NewYall Cast Aluminum Thermostat Housing Cover Coolant Flange Cooling Hose Water Distribution Pipe Upgrade Kit
Amazon Amazon
Old 03-04-2020, 01:39 PM
  #1881
vt951
vt951's Avatar
Originally Posted by hinton
NewYall Cast Aluminum Thermostat Housing Cover Coolant Flange Cooling Hose Water Distribution Pipe Upgrade Kit https://www.amazon.com/dp/B07QS2T618..._XbjxEbQCBA8XV
yeah this kit is perfect because you can also use the y fitting to tie in the turbo water return hose to the bypass hose coming out of the rear coolant flange.
Old 03-04-2020, 01:56 PM
  #1882
vt951
vt951's Avatar
Default Oil Pans
Almost ready to ship! It’s been a long and sometimes frustrating road, but I’m happy with the result.
The upper pans are ready to ship as is, but I think we’re going to treat them to a little cosmetic surface finishing with a brass cup brush first.
I finally got my zinc plating setup dialed in as well as I can. The plating is not exactly pretty, but it seems to be tough. We will be ceramic coating the outside of the sumps for appearance as well as additional corrosion protection.
The following 2 users liked this post by vt951:
dmnted (03-04-2020), Sixline (03-04-2020)
Old 03-04-2020, 02:12 PM
  #1883
senior_squishy
Looks fantastic. I'm so excited to do this swap, It's been quite a journey. So, Alan, Mike, would you recommend installing the upper sump first, drop engine in, and then install the lower pan? What's worked for you guys in the past?
What's the status on the rest of the parts, will their ship times line up with the pan & intake do you think? (Mike quoted me 3/31 but I'm optimistic &#128541
Old 03-04-2020, 02:19 PM
  #1884
vt951
vt951's Avatar
I am optimistic that everything else will be ready to ship with the pans (probably in separate boxes anyway due to the shear size of everything). Intake manifolds are done and in process of shipping to us from Brazil.
Old 03-04-2020, 02:25 PM
  #1885
hinton
hinton's Avatar
We recommend putting the lower sump on first, as there is one bolt that is really tough to get to otherwise.
You can get it in with the subframe hanging by the caster blocks but it’s by far the easiest if you do it with the subframe out, just like the OE engine. If you are doing it solo you definitely need to drop the whole subframe in order to line up the pilot bearing and torque tube.
Old 03-04-2020, 02:30 PM
  #1886
senior_squishy
Okay, I'm assuming you mean the front crosmember, that makes sense. Ill probably have a helper with me to line everything up but this is good info. Thanks Mike!
Old 03-04-2020, 02:44 PM
  #1887
senior_squishy
Old 03-07-2020, 01:19 AM
  #1888
hinton
hinton's Avatar
Our first batch of tensioner pulleys has arrived!
The following 3 users liked this post by hinton:
JWebber (03-07-2020), senior_squishy (03-07-2020), Sixline (03-07-2020)
Old 03-07-2020, 09:35 AM
  #1889
senior_squishy
Sooooo... 8200rpm Dyno run for next video?😏
Old 03-07-2020, 09:45 AM
  #1890
hinton
hinton's Avatar
Ha, might need a cam and valve springs before that’s a reality
Quick Reply: VW/Audi 07K (2.5L 20V I5) Swap Thread
