Refresh951's Hybrid Ultra Stroker Build
Old 08-30-2013, 11:57 PM
  #886
mudbuddha
mudbuddha's Avatar
Nice choice. What are those- fikse profiles? With over 400 horses to the rears, you definitely will need wider rubbers. No more test fitting- put them on already!
Old 08-31-2013, 12:35 AM
  #887
333pg333
333pg333's Avatar
99% sure they're the Mach V's?
Old 08-31-2013, 12:39 AM
  #888
refresh951
refresh951's Avatar
Thanks! Fiske Mach V's. Got a really great deal on them.
Old 08-31-2013, 12:49 AM
  #889
333pg333
333pg333's Avatar
Great wheel in my opinion too. :-)
Old 08-31-2013, 12:57 AM
  #890
refresh951
refresh951's Avatar
Thanks Patrick. I have Josh B to thank for finding me a great deal on these wheels. He has given me a ton of great advice with respect to my wheel and suspension setup.
Old 08-31-2013, 05:46 AM
  #891
Dutch944
Dutch944's Avatar
Real nice set of wheels Shawn!
Old 08-31-2013, 09:48 AM
  #892
333pg333
333pg333's Avatar
Well I can't lay claim to any quantifiable information but from what I've experienced, these are a quality wheel which has the advantage of being repairable. I've just got 2 more sent down here so I have two sets of 11.5" x 18" all round. Means that we can run a square setup x2. The build quality looks absolutely first rate. I have heard less than satisfactory feedback on Forgelines which appear to be quite similar. Not sure of the differences but I am sure you'll be happy with these new boots Shawn.
ps...am interested in your take on that link Duke posted re Inj's. Have you had a chance to play with it? http://www.rceng.com/technical.aspx
I'm interested as far as trying to "even up the playing field" in terms of dyno numbers. I know that some have proposed e.g. 100-200kmh times. Others have made a calc based on 1/4 terminal speeds. As we've progressed in the 951 world I see that some others are equating inj size and duty cycle to equate power figures. As we know there is always going to be discrepancies between dynos, and even countries of origin. Also as many of us have conceded that in reality the dyno is really only a tuning tool and something to compare the previous setup against. I will be posting my results in a few weeks time and am anticipating lower figures than others would guesstimate given similar modifications. It's all academic to a degree but am more interested in something that is quantifiably measurable.
Old 08-31-2013, 11:18 AM
  #893
V2Rocket
Rainman
V2Rocket's Avatar
I know that some have proposed e.g. 100-200kmh times. Others have made a calc based on 1/4 terminal speeds. As we've progressed in the 951 world I see that some others are equating inj size and duty cycle to equate power figures...It's all academic to a degree but am more interested in something that is quantifiably measurable.
100-200kmh is a nice round measurement but in terms of legal practicality, what about a 70-170kmh run, 3rd gear only? we've all more or less have the same ratios and tires are about the same diameter, so 170 is about as much as 3rd gear goes and thats really the gear used most for easy highway passing.
that would give you a pretty good representation of the whole RPM range and no worries about shift-time discrepancies when you have to hit 4th to get to 200kmh.
Old 08-31-2013, 11:25 AM
  #894
eman930
eman930's Avatar
Dude with the 951 you don't have to downshift to pass on the highway, mine still pulls good in 5th lol
Old 08-31-2013, 01:35 PM
  #895
refresh951
refresh951's Avatar
My take, these calcs are useful for sizing injectors but when trying to use them to compare between different setups it would be problematic. Things like assumptions of BSFC and variations in injectors along with different tunes would make it difficult to compare different setups. A/F ratio impacts duty cycle. A 1 point difference in A/F (say 12 vs 11) results in about 7% difference in fuel. I could see it useful to use duty cycle on a given car to generalize hp level in the same way you could use maf voltage.
I think the dyno has been a useful tool for me because I have used the same dyno and knowledgeable operator for all my runs and for the most part I am comparing results with previous runs. I also think my early runs (238 hp, 15psi, A-Tune, and test pipe) demonstrated reasonable and expected results.
Looking forward to your dyno Patrick. The car looks amazing.
Old 08-31-2013, 10:46 PM
  #896
Josh B
Josh B's Avatar
Wheels look great - can't wait to see the car in person
Old 09-01-2013, 01:14 AM
  #897
Thom
Thom's Avatar
Loading the engine in 4th is more relevant to its performance than loading it in 3rd gear.
To me the 100-200 km/h through the gears is more relevant because it gives as much indication from the engine power as the car's dynamics. A properly set up car with less power can be faster than a heavier car with more power, for instance, and acceleration matters more than hp.
Old 09-01-2013, 02:11 AM
  #898
333pg333
333pg333's Avatar
I suppose that if you can reach 200kmh then you could run logs between any speed comparisons. This might be a bit fairer as there will be people with different gearing or transmissions.
Old 09-01-2013, 11:49 AM
  #899
Paulyy
Professional Hoon
Paulyy's Avatar
For me 3rd gear 100-160 km/h is good. Just because it's easier to do.. But comparing times will be in the nearest .1 or less of a second. As 100-160 km/h uses all of 3rd gear. But the load wouldn't be the same in 4th.
Old 09-04-2013, 03:19 PM
  #900
CyCloNe!
CyCloNe!'s Avatar
Sweet wheels Shawn!
Quick Reply: Refresh951's Hybrid Ultra Stroker Build
