Rennlist Top 10 HP/TQ
Old 09-23-2005, 04:58 PM
  #466
NZ951
NZ951's Avatar
If anyone can recall, can they post the diff ratio they used... cheers!
Old 09-23-2005, 05:07 PM
  #467
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
I made a mistake in my previous post, DFASTEST951 rennlister (Joe) currently has and runs 52 LBS/HOUR @3.0 BAR FUEL PRESSURE ( Click here )
No Joe, i am not attacking you, just stating facts and the obvious. And i have yet to see a good and valid explanation, and NZ keep you're mouse away from the bad post report button, since you yet to have anything valid so far.
Old 09-23-2005, 05:13 PM
  #468
TRWright
TRWright's Avatar
Alright guys, I think there is some pretty serious confusion on here regarding the dynapack dynos. Here is a run that I did recently with my clutch slipping like it was covered in 5W-30!
Please note that it says Flywheel TQ and HP. Also notice that the correction factor is 1.00. The TCF stands for total correction factor. If 1.15 was entered, the dyno would tack on 15% to the wheel numbers. If they enter 0.85 for a TCF, the dyno will knock 15% off the wheel number. 1.00 is what the car is making at the wheels. No matter what, "flywheel" is is what the dynapack chart will read.
Old 09-23-2005, 05:16 PM
  #469
hosrom_951
hosrom_951's Avatar
Thank You Ted!
Old 09-23-2005, 05:26 PM
  #470
NZ951
NZ951's Avatar
Hey Ted, how did you calculate the diff ratio 3.810?
Old 09-23-2005, 05:34 PM
  #471
RKD in OKC
RKD in OKC's Avatar
The reason I made that comment was to give you some ribbing about your dyno sheet print out. You say it's has the SAE correction, yet Bills dyno sheet from a dynapack dyno (submitted on page 13 of this thread) has Hp SAE listed in the legend where your's does not.
You say your's is corrected, Rob says the dyno guy tells him it is rear wheel and NOT flywheel. If you are not going to accept Rob's sheet, you shouldn't accept you own most recent submission.
Just go back to the dyno and have them print you an SAE corrected graph. My local dyno stores all the runs they have made for furture reference.
Old 09-23-2005, 05:41 PM
  #472
NZ951
NZ951's Avatar
I have got the corrected chart, I posted it. Notice Ted's chart does not have corrected next the the HP on the axis either? I guess we have learnt that not all charts on al dynos print out the same. Thanks for the ribbing, have fun out there!
Anymore more issues, please direct them to my PM. I dont want my thread to get closed because of bickering. Thanks guys!
Old 09-23-2005, 05:44 PM
  #473
hosrom_951
hosrom_951's Avatar
And what about Robert's chart??
Old 09-23-2005, 05:46 PM
  #474
NZ951
NZ951's Avatar
BUMP
Old 09-23-2005, 06:53 PM
  #475
TRWright
TRWright's Avatar
I didn't calculate anything. The dyno operator did everything. From what I understand, there are a lot of variables that can be messed up on the dynapack.
Old 09-23-2005, 07:20 PM
  #476
NZ951
NZ951's Avatar
I am sure there are a lot of variables on a lot of dyno's. Anyone else know their diff ratio?
Old 09-23-2005, 08:19 PM
  #477
NZ951
NZ951's Avatar
PS The changes I have made since my last run include a dump to ATM WG, which reduced exhaust pressure to under 1psi from 6psi, and I also ran another .5psi of boost Happy days!
Old 09-23-2005, 10:20 PM
  #478
stewardx
stewardx's Avatar
"PS The changes I have made since my last run include a dump to ATM WG, which reduced exhaust pressure to under 1psi from 6psi, and I also ran another .5psi of boost Happy days!"
I think you would agree this shows your 3 inch exhaust was to small.
Wes
Old 09-23-2005, 10:25 PM
  #479
NZ951
NZ951's Avatar
What 3" exhaust?
Old 09-26-2005, 02:16 AM
  #480
DFASTEST951
DFASTEST951's Avatar
So...if you correct my dyno on my dyno dynamics machine and convert it to dynojet....then....I'd be over 500 whp! Great! Put me up.....JUST KIDDING!!!!!!!!!!!! I like my numbers just where they are knowing they are really higher. I'll wait for the proof with the rest of you guys. Gots to get back to the dyno...
Quick Reply: Rennlist Top 10 HP/TQ
