Porsche 944 Turbo restomod
#286
I will have more pictures soon!
Just a quick note on the tuning capabilities with the AugTronic ECU.
I have only done two short drives to have a look at the base map and the way I can adjust fueling. Tomorrow I will have someone assisting me. Driving and tuning is not a good combination.
The base map is on the rich side (by design). Live tuning is very easy! I have hooked up a Zeitronix Wideband to the AugTronic ECU and the ECU is capable of auto adjusting. You set up a map with target AFR's and the ECU tries to match that AFR. That part is disabled for the moment. I will try to get as close as possible without auto adjusting.
The software can auto-select the active cell in the map which makes it very easy to adjust.
The log file created by AugTronic ECU contains tons of information. All that information can be analysed perfectly with MegaLogViewer HD.
The AugTronic ECU does not have a log viewer and frankly I wouldn't spend any time creating a log file viewer when MegaLogViewer HD is available.
This weekend I will see if I can find some interesting screengrabs and post it here.
#288
Yes, previously I rented a unit with car lift, but when a neighboring unit had a fire (and I had to take my car apart again to clean all the smoke deposits) I transported my car to my (small) garage at home. At that point most of the car was done, but I still had to put in the engine.
Update:
It has been raining the last few weeks, so I was not able to take the car out for taking care of the fuel maps. I did mange to cleanup the idle map. The idle was dancing, but I was able to correct the fueling and idle screw position.
I have ordered new steering rack parts and will have my manual steering rack rebuild. While driving I noticed sounds (while steering) which pointed into the direction of steering rack issues.
With a bit of luck I will be able to tune the off boost fuel maps this month, but when not the car will be sitting in the garage until March next year.
Update:
#289
Update:
Update:
Can you show us pics of your interior? Has it been put in? It would be awesome to see a restomoded interior. Amazing work.
#290
A ton off pictures on https://www.bakkumit.nl/944ls3/Gallery/Loading
#291
y Frank@Work.. you're driving the restoration? That beautiful white one? Sorry.. seem to have missed the thread lately. That work you done is special
I am working on taking care of the issues, but the season is over (in The Netherlands). Expect to be driving in March 2021 (if the weather allows it).
The issues I am/have been working on:
- Some play in the manual steering rack; send it out to be checked and got it back after a minor adjustment. The screw which pushes the rack to the pinion was too loose. Ordered the last steering shaft from 944online (but did not put it on the car). Put in new steering rods with new rod ends.
- Tracked down a small oil leak in the lower oil cooler line. Fixed it with vulcanising tape (for now). Ordered a brand new (ridiculous expensive) oil line which I will put in when I change the running-in oil for the normal oil.
- Still tracking down a small oil leak near the thermostat/oil filter housing. Hard to see where the oil comes from.
- Tracking down a resonance. Found the 3" exhaust hitting the protecting plate at the flywheel. Fixed it, but still the resonating sound. Took off the inlet manifold and the flywheel sensors yesterday. I would like to re-gap the sensors. However, no indication on the sensors that something has been hitting a sensor.
#292
Also.. I can't believe just how much the adjustment of the front wheel bearings can affect at the steering wheel. It's precision surgery: I have adjusted them a few times now, and finally it feels solid & drives straight and smooth. Each time, I would say the adjustment is no more than 15-20 degrees rotation of the nut.. and I've ended up tighter than the instructions allow (ie. can't move the washer)
#293
Mine has also a little bit of on-center play. The rebuilder told me to ignore it, because the steering rack is in good condition with the exception of a tiny bit of on-center play. Only way to get rid of that play is to source another rack without the play.
#295
Really a superb build want to come to ny to do mine free room and board and I’m in NYC you came build it anytime
Mike
Mike
#296
#297
I hear you and I will try out different wheel bearing settings. Nevertheless, my steering rack (on center) play was diagnosed with the steering rack on a workbench. I can't imagine I can get rid of that play by adjusting the wheel bearings.
I really suggest playing with the wheel bearing adjustment. I have found crazy differences in steering and front-end behaviour from ridiculously minor changes in the nut. Personally, I got the best results following Mike's video (note this ends up tighter than the factory procedure):
https://youtu.be/GXLQSENcetk
#298
I'm having an issue (again) with the speed and reference sensors. I think the reference sensor mark is hitting the sensor, but cannot see any damage on the sensor. I have taken out the sensors and removed the sensor bracket (after removing the heater valve which was in the way). It seems when I gap the speed sensor as per WSH the reference sensor mark is hitting the sensor. I'm a bit fed up with the crap location for the sensors.
I have asked the AugTronic ECU supplier if the system will work with a Clewett 60-2 trigger wheel setup. Repositioning the sensor to the front of the engine will probably keep me sane.
Are there any drawbacks on using a 60-2 setup on the Porsche 944 Turbo?
