928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 05-29-2018, 12:26 PM
  #7531
ltoolio
ltoolio's Avatar
Like OTR, not today, but over the weekend.
Took the wife out for a drive on Monday, and for the first time in the 3 years of having the car, she said "wow...that was an enjoyable drive".
#success
Old 05-30-2018, 01:33 AM
  #7532
Mikebte
Mikebte's Avatar
Originally Posted by Basal Skull
My oldest car now has the most advanced radio...
love that radio, was hard to justify the price for my US 80, but super nice.
Old 06-03-2018, 06:52 PM
  #7533
Hymodyne
Hymodyne's Avatar
finally got oetiker clamps on both CV boots at the flange ends, passenger side. Had to take the half shaft off the car again. Driver's side is next, followed by a refilling of the gearcase and differential and replacement of the fuel tank.
James
Old 06-13-2018, 04:47 AM
  #7534
MainePorsche
MainePorsche's Avatar
It’s been awhile.
Compressor clutch had failed so replaced compressor and dryer. System held vacuum well and was an easy refill.
Painfully ice cold again.
Old 06-13-2018, 07:03 AM
  #7535
voskian
voskian's Avatar
Craig, glad to see you on here, hope alls well.
Wired up my front coupler so I can make the drive up to Camp 928. Broke the insert on some hard 1-2 shifts during autocross. I’ll have to make permanent fix after the weekend. Car shifting action relatively smooth!
Old 06-13-2018, 12:02 PM
  #7536
MainePorsche
Hey there Bob.
Great pics. Looks like a good time.
Forgot to add earlier, replaced the headlight washer diverter valve. A neck stem had broke to one of the lights. Did it without removing the nose. Hoses routed the same, just located the diverter valve under the headlight torsion bar closer to the Right headlight hose fitting and refitted the main feed hose below the retracted headlight. Works well, and all moving parts clear.
Old 06-13-2018, 12:24 PM
  #7537
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,207 Likes on 467 Posts
Nice to see you back Craig!
Old 06-13-2018, 06:43 PM
  #7538
Stevenwr
Stevenwr's Avatar
Default Finished Intake refresh
I finally finished an intake refresh on my 88 S4. Took the car out for a drive today, first time since last fall. I noticed the idle is more stable and it seems to accelerate more quickly.
Old 06-13-2018, 10:58 PM
  #7539
Hymodyne
Hymodyne's Avatar
Your lovely engine bay prompts a question off topic: why are there holes in the underside of the tubes that feed the air box?
James
Old 06-13-2018, 11:20 PM
  #7540
Wisconsin Joe
Wisconsin Joe's Avatar
Do you mean the ones that go into the top of the TB cover?
They are there to provide a 'draw' for the air inside the cover.
Drawing out the old air and allowing fresh air to replace it.
There are various thoughts on why that is done.
Old 06-14-2018, 11:07 AM
  #7541
Hymodyne
Hymodyne's Avatar
I meant on the underside of the air tubes that connect to the air box. My tubes are shaped exactly the same way, corrugated in parts and each has a few quarter sized holes on its underside.
James
Old 06-14-2018, 11:38 AM
  #7542
Christopher Zach
Christopher Zach's Avatar
Swapped in another CC brain, this is my third attempt:
The first one would almost never work, but when it did and I tried to set a speed it would go past 100mph.
The second one worked for 2 days, then went odd. I could hear the CC relay click when I engaged it, but it would not hold a speed. It would however accel when I pushed the stalk forward.
Third one ("good" bought from Ebay) worked, then didn't work, then worked again. Need to try it a bit more. Would accell when I pushed the stalk forward.
Mi
Old 06-14-2018, 08:53 PM
  #7543
Stevenwr
Stevenwr's Avatar
I removed my intake tubes and the only holes are the ones that connect to the TB covers.
James
Old 06-14-2018, 09:27 PM
  #7544
Petza914
Petza914's Avatar
Received 6,171 Likes on 3,935 Posts
Installed a new cold air intake on my 928MS supercharged Spyder. Draws air through a 4" inlet in the driver's side fender well, takes it through a carbon fiber airbox with K&N filter in it, and into the supercharger inlet.
Old 06-14-2018, 09:48 PM
  #7545
Hymodyne
Hymodyne's Avatar
Got it. many thanks for all replies.
Quick Reply: So what did you do to your 928 Today......
