So what did you do to your 928 Today......
#7411
Took her on a nice, quick drive to the airport this morning. Makes coming home extra special.
#7414
I was a fairly busy little bee today; took apart the heater control, replaced the mixing levers, replaced the bulb at long last and checked the AC relay (still good). I'm going to put a booster relay in the front to run the fan and the compressor since I think that's too long a run and too much voltage drop to do from the control.
Also fixed the passenger front and rear seat latches so they fold back, just needed a bit of tapping with a hammer then some grease.
Swapped out the cruise control computer, now have actual working cruise control!
And I'll replace the footwell vacuum bladder so I have at least two of the four servos working (the other is the outside air flap; the defroster and comb filter are shot and blocked off)
Getting there, one step at a time....
C
C
#7421
C
C
#7422
It is Vinyl, being my 1st go, I wanted to be cheap incase I did a terrible job.
#7424
