928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 02-21-2014 | 11:42 PM
  #4531
MjRocket's Avatar
MjRocket
Originally Posted by OTR18WHEELER
Replaced rear brake pads, rotors and wear sensors today, changed the oil and filter yesterday.
Otis
Glad to hear you were able to get the brakes done.
Old 02-22-2014 | 12:26 AM
  #4532
OTR18WHEELER's Avatar
OTR18WHEELER
You can call me Otis
^had to get it done, running out of time.
Old 02-22-2014 | 02:19 PM
  #4533
82Porsche928's Avatar
82Porsche928
Took her to cars and coffee with my son to show off her new stealth mirrors, which I did yesterday!
Still can't decide if I like them in black? You?
Old 02-22-2014 | 02:37 PM
  #4534
the flyin' scotsman's Avatar
the flyin' scotsman
all plans were scrapped as the temps went into real winter AGAIN!!! -18c
Old 02-22-2014 | 05:58 PM
  #4535
RedRaider1's Avatar
RedRaider1
78 here in Dallas today. Taking advantage of the beautiful day to condition the leather in the 928 and wash both the 928 and 911. So ready for spring, but not looking forward to the heat of summer.
Old 02-22-2014 | 06:15 PM
  #4536
Avar928's Avatar
Avar928
Originally Posted by The Forgotten On
They carry tons of parts for our cars, the trick is to look up the OEM numbers and not the Porsche numbers. I've saved $$$ by doing this.
I'll be checking Amazon from now on also. Probably be able to find some of the more miscellaneous items I need that aren't readily available.
Took her for a spin and put some miles on her after finally putting an end to the transmission leak. Gave her a long overdue washing. The only leaky gravity drops I have now on the garage floor is oil coming from the pan bolts. That's a summer job along with motor mounts and a rebuilt steering rack. Next I'm going to pull and replace the FPR and damper. Re-seat the passenger side fuel rail and finally install the Porken chips
Old 02-22-2014 | 08:08 PM
  #4537
jwbeck17's Avatar
jwbeck17
I took advantage of the rare warm up here and completed my expansion tank install. Got the coolant in her, then started her after she sat through most of the winter. She started up pretty well, telling my my winter reinstall of the alternator worked out fine. Had a few fuses to fix, but she's back in good shape.
Sadly, I can't drive her around due to the horrible roads right now.
Old 02-22-2014 | 08:13 PM
  #4538
HaydenM1974's Avatar
HaydenM1974
Originally Posted by 82Porsche928
Attachment 808928
Will have to join you some Saturday...first need to take care of finding a reasonably priced front spoiler and brake duct grill. Just got the 84 928 home today.
Old 02-22-2014 | 08:22 PM
  #4539
82Porsche928
My front spoiler is badly damaged, and I have no grille. I am in desperate need of one, but don't want to spend the $$$ they ask. There is a wrecked 928 at a body shop by my house, I'm going I check and see if they will sell me theres...
Old 02-22-2014 | 08:40 PM
  #4540
HaydenM1974
There is someone parting out an 82 928 on Craigslist Las Vegas....not sure if that part is still available
Old 02-22-2014 | 09:58 PM
  #4541
DKWalser's Avatar
DKWalser
I replaced the bulbs in the pod switches. (No, I didn't upgrade to LEDs. That'll be part of a much larger project to come.) I also bought the 928 its own remote for the garage door opener. Eventually, that will be replaced with a Homelink system when the inside rearview mirror gets updated to a self-dimming model.
The list isn't getting any shorter.
Old 02-22-2014 | 11:45 PM
  #4542
82Porsche928
I will call tomorrow, thank you!!
Old 02-23-2014 | 12:04 AM
  #4543
ammonman's Avatar
ammonman
Took advantage of afternoon highs in the upper 60F range and put 200 twisty mountain miles on the odo.
Happy Times.
Mike
Old 02-23-2014 | 11:26 AM
  #4544
jorgens's Avatar
jorgens
Took both rear calipers off, gave them a thorough clean, added some grease to the sliding areas and re assembled. Smooooth operation now
Jørgen
Old 02-23-2014 | 03:45 PM
  #4545
LT Texan's Avatar
LT Texan
Have a bumping sound from the rear. So tied down the Borla so it couldn't bang against the battery box or sway bar control link.
Didn't work.
So I raised her up and started banging things around and looking for anything loose. Started on the right side. Nothing.
On the left side the transmission cross member bolts were loose.
The forward one a little and the rearward one a lot. Or at least enough for a turn or so.
Never touched these before.
Quick Reply: So what did you do to your 928 Today......
