928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 02-15-2014, 11:55 PM
  #4516
DKWalser
DKWalser's Avatar
Today:
  • Replaced the rear hatch struts
  • Installed a new-to-me used cargo net
  • Gave her a bath and a wax
Old 02-16-2014, 03:55 AM
  #4517
Ladybug83
Ladybug83's Avatar
Originally Posted by willbj3
sorry for the late reply.. Been vacationing ..repaint due to the wrong color on the first round of a repaint.. Fixed the non working tail light problem.. Working in the interior now , bought a used leather dash to recover before taking out my existing dash...but getting the sunroof to work has brought a smile to my face most of all.. Yes this is my second spoiler sold the first one for a decent profit.. Can't decide if I want to add a spoiler to my car..maybe the 928 police will say it's not factory..
I like no spoiler and I like the s4/gts spoiler. Not a big fan of the 3 piece, but I'll leave mine alone for now. Seems like deleting is harder than I thought with all the glass trim that has to be changed.
Gave up on my sunroof and headliner a while back, decided to clean it up and leave it. Wanted to dynamat the roof but the sunroof/headliner gave me too much trouble and I didn't want to damage it more.
Finished shaping and gluing dash panels today. Will start sewing next weekend.
Sent from my iPhone using Rennlist
Old 02-16-2014, 07:01 AM
  #4518
Schocki
Schocki's Avatar
Default Rear hatch release motor
Modified the ground connection to my rear hatch release motor on my GTS.
Brn/wht cable from the motor to direct ground. Now the hatch opens if the door is closed or open
Old 02-18-2014, 02:28 AM
  #4519
Ladybug83
Ladybug83's Avatar
Finished sewing new dash vinyl
Old 02-18-2014, 05:07 AM
  #4520
Hilton
Hilton's Avatar
On my '87:
Pulled the fan shroud and fixed a leak from one of the PS hoses (non-pressure line onto cooling loop).
Added some anti-squeal to the back of the rear brake pads.. much improved on the noise front
Put the stock S4 rims on with the new tires.
Drove it around a bit until properly warm, and adjusted the warm idle mixture to 14.7 AFR (I don't have a gas analyser to do it by CO). Its a non-cat car, being from Europe, so no O2 sensor.
Interestingly, with a freshly rebuilt JDS MAF, I had to turn the MAF compensation almost to the very end of the adjustment range (97% according to my ST2's fuel system readout) to get there.
Old 02-18-2014, 06:09 PM
  #4521
John Speake
John Speake's Avatar
Well, you have lots of range to compensate for ageing :-)
Old 02-18-2014, 06:20 PM
  #4522
the flyin' scotsman
the flyin' scotsman's Avatar
built the engine support by Andrew O to complete the engine mount project on GTS......works like a charm......thx Andrew.
Old 02-18-2014, 06:29 PM
  #4523
Chalkboss
Chalkboss's Avatar
Easiest job by far and most bang for the buck- window switch not working well on the down position. Had to press like a **** in just the right spot. Disassembled and did the old plastic shaving trick on the housing. Took about two minutes. Works like a champ now. Why did I wait a year...!
Also put on all new decals (Jaeger) for the window/sunroof etc switches. They look real nice.
Old 02-18-2014, 07:15 PM
  #4524
TheClairvoyant
TheClairvoyant's Avatar
Used a broom to brush snow off its car cover.
Old 02-19-2014, 01:26 AM
  #4525
Ladybug83
Ladybug83's Avatar
Installed defroster vents over new dash vinyl and tied up the loose ends
Old 02-19-2014, 01:34 AM
  #4526
SeanR
SeanR's Avatar
^^ looks sharp.
Old 02-20-2014, 01:01 AM
  #4527
risaac928
risaac928's Avatar
Upgraded to some H4s....
Old 02-21-2014, 02:32 PM
  #4528
Avar928
Avar928's Avatar
Tried again to fabricate a transmission line hose. Apparently the dirt helped sealed the fitting to hard line and it continued to weep ATF slowly no matter how tight I made it or if I used thread sealant. Mating surface looked scoured, probably my fault when uninstalling.
Went on a limb and bought the OES hose from Amazon. Didn't have the part number but a manufacturer number and Amazon fitment said it was the right one. Just arrived today...and it IS the right hose. Correct part number, made in Germany, genuine Porsche. I saved $25-30 if I had bought it elsewhere and I got free 2-day shipping (Prime).
Who knew Amazon actually carried genuine 928 Porsche parts?
Old 02-21-2014, 06:44 PM
  #4529
The Forgotten On
The Forgotten On's Avatar
They carry tons of parts for our cars, the trick is to look up the OEM numbers and not the Porsche numbers. I've saved $$$ by doing this.
Old 02-21-2014, 11:35 PM
  #4530
OTR18WHEELER
You can call me Otis
OTR18WHEELER's Avatar
Replaced rear brake pads, rotors and wear sensors today, changed the oil and filter yesterday.
Quick Reply: So what did you do to your 928 Today......
