928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 04-28-2013, 12:54 AM
  #3811
STRIKEMASTER
STRIKEMASTER's Avatar
Smile on the road again
finished re-wiring the 14 plug connector, had to cut back the wires about 6" to get to good copper. Fired up the '83 euro and roared down the road for a bit. It looks like I'll be in the market for a wire harness in the near future, now I just have to find one. "Some sharks do 150, some do 149, If I can make mine run at all I think I'm doing fine"
Old 04-28-2013, 03:45 PM
  #3812
LT Texan
LT Texan's Avatar
Took the passenger door panel off to resolve a rattle.
And after 23 years, finally repaired the door lock ****. I guess it was installed without regards to actually connecting to the lock rod!
So, no rattle. And the door locks all work, vacuum actuation and all!
Old 04-28-2013, 11:04 PM
  #3813
curtisr
curtisr's Avatar
Removed power front seats today. Will install the SPARCOs soon. Found 'lost' sunglasses between passenger front seat and console hump. Woot!
Old 04-28-2013, 11:10 PM
  #3814
jeff spahn
jeff spahn's Avatar
I pulled and replaced the front main seal. Took about 4 hours.
Thanks to Rob Edwards for the loan of the Porsche 9125 seal installation tool. Made it fool proof!
Thanks to Sean Ratts for the advice prior to installation.
Old 04-29-2013, 12:48 PM
  #3815
911tracker85
911tracker85's Avatar
great group drive Saturday with the Buckeyelandsharks club. in addition to the sharks in this pic, we had a few other sharks but they did not come to this spot for final pics with the great white shark on the billboard sign. just could not resist this pic opportunity.
Old 04-29-2013, 12:50 PM
  #3816
NC928S4
NC928S4's Avatar
Worked on center console plastic repair. Meathead PO must have missed a few screws that were holding the console in place so he just ripped it out. The top 2 screws that fasten the top of the console to the dash had broken all plastic on top of console which meant air was blowing into dash rather than into cabin. I picked up some tin sheets and pop riveted formed plates over the holes. The plates with liberal all weather caulking seem to work. The pics are sketchy and I still need to drill mounting holes on top of console. Also replaced a broken plastic flange.
Old 04-29-2013, 04:53 PM
  #3817
4drgl
4drgl's Avatar
driving her and working bugs out one by one after a 3 year sit. And a prior who knows how many yeas lack of maintenance!!
Really liking the car so far!
Old 04-29-2013, 10:30 PM
  #3818
Lizard928
Lizard928's Avatar
Getting everything prepped to install a turbo on an 82 (with 4.7L now).
Wasnt able to baseline today. Should be able to do so tomorrow.
Some of the exhaust is getting ceramic coated, and manifolds will be converted to V-band!
Old 04-30-2013, 11:54 AM
  #3819
928DK
928DK's Avatar
Changed front and rear brake discs and pads.
  #3820
928DK
928DK's Avatar
Changed oil and found this stuck to the oil plug magnet:
only a year since the cams/springs/spring cups were installed
also now the oil hose going from oil cooler to oil filter is leaking.
Old 04-30-2013, 12:06 PM
  #3821
928cs
928cs's Avatar
Removed the rear wiper system.
Old 04-30-2013, 12:09 PM
  #3822
SeanR
SeanR's Avatar
Is that part of a valve spring?
Old 04-30-2013, 12:19 PM
  #3823
928DK
928DK's Avatar
yup
looks like (a part of) an inner coil
ill tear down the heads next week and look further into the matter
bought the springs dec2010 in a lindsey racing group buy and installed them last year
Old 05-01-2013, 09:50 AM
  #3824
dzaprev
dzaprev's Avatar
Drivers side door handle hinge replacement and ps pump....well actually last night
Old 05-01-2013, 10:46 AM
  #3825
atb
atb's Avatar
Please post your findings in a new thread, I think there was another similar failure from the same group buy.
I just installed my set and am now concerned, what are you running for cams?
yup
Quick Reply: So what did you do to your 928 Today......
