928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 08-13-2011 | 03:05 PM
  #1591
finally!'s Avatar
finally!
Originally Posted by 77tony
Your ride is looking sweet. Why don't you take a nice picture of it, and use it for your avatar picture? T
Mostly because my camera skills suck...
Also replaced relay in Sean's test head unit with new one, tested and all good! The old relay in his was melted so much that one of the legs was gone! While I had repaced the relay in mine a couple weeks ago I went ahead and swapped a new, smaller one, into it today so the relay is hidden inside the HVAC head unit. Also put a resistor on the power wire to the LED which lights up my HVAC fan ****.. damned thing was so bright before it was liking having a flash light shining through it!
Old 08-13-2011 | 07:10 PM
  #1592
jeff spahn's Avatar
jeff spahn
I put a new relay in my ac head unit per dwaynes instructions. Hans gave a push to get me past a tough spot cause my 90 head unit is not the same.
Old 08-13-2011 | 09:41 PM
  #1593
risaac928's Avatar
risaac928
Patched up my leaking gas tank.....now to see if the patch work will hold.
Old 08-13-2011 | 10:15 PM
  #1594
Hilton's Avatar
Hilton
Jeff - if your 90 had a yellow relay instead of the earlier blue Gruner one, there is a direct replacement available for it in a suitable rating - no need to add wires etc. There's a thread here on Rennlist by a UK chap about the part numbers.
If it was a blue gruner, then there is no replacement, hence the wires and out-board relay.
Old 08-13-2011 | 10:48 PM
  #1595
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
Pulled the CE panel out of the GTS, did the cleaning thing. Brass brush in the dremel for fuse and relay contacts, scratch brush on all the terminals, Deoxit D5 in the relay bases, and Stabliant 22A on everything during reassembly.
Old 08-13-2011 | 10:55 PM
  #1596
jeff spahn's Avatar
jeff spahn
Hilton. It had a matsu****a relay
6 pins.
Old 08-13-2011 | 10:57 PM
  #1597
jeff spahn's Avatar
jeff spahn
I am bummed because when I pulled the wiring harness for the engine I broke two of the little top tabs on the two CE plugs that come out with the ignition harness.
Old 08-13-2011 | 11:07 PM
  #1598
Rob Edwards
Archive Gatekeeper
Hell, I broke at least 3. Strangely all the broken ones were brown.
Old 08-14-2011 | 03:43 AM
  #1599
Ad0911's Avatar
Ad0911
Originally Posted by aaddpp
Finished rebuilding / refreshing the wiper motor, including new bearing and grease. The four brushes were a beast to deal with, but eventually went back in. Bench tested the motor and its working smooth and quiet. Just need to seal the casing with some strip caulk in the AM. Thankfully that's the last component that requires any attention in the back bay.
On to the clutch bearing / pack, and clutch hydraulics tomorrow.
Getting there...finally.
I take it this is the rear wiper motor? I am working the front wiper mechanism and motor now. The wiping action was too slow. When I dismantked it, there wasn't any play to speak of in the mechanism but the wiperblade axles did have the chromium worn off one of them. My local garage advised me to just grease it up again. The brushes in the motor looked fine to me so I did not replace them. Keeps me wondering why the wiping was so slow. My car is a '78 with approx 90000 miles on it but neglected in the last years of the PO so lots of work on it.
Old 08-14-2011 | 04:08 AM
  #1600
jpitman2's Avatar
jpitman2
I got the dash fixed and back in !!! blue leds even work! And she still runs! Woo Hoo!!!
Did not enjoy it much, but in the end the cure was simple - bend the contact blades in the connectors, cos they are too d@mn soft.
jp 83 Euro S AT 53k
Old 08-14-2011 | 12:18 PM
  #1601
finally!'s Avatar
finally!
Changed the oil and cleaned all the grounds in the engine bay while I was at it. In preperation of driving to Eureka Springs, AR next weekend for belated anniversary trip with the wife... WOW! Cannot beleive it has been (she has put up with me) 28 years!
PO'd though that I misordered the Valentine 1 remote display when meant to get the remote control unit.. BLECH! Means possibly no V1 for the trip!
Gonna install the LED converted 3rd brake light today too... Only other thing left is driver carpet piece install, had installed new carpet about a month ago but botched the cutting of the hole for the hood release so had to order a new one.. :P
Old 08-14-2011 | 06:00 PM
  #1602
jeff spahn's Avatar
jeff spahn
Installed new O2 sensor.
Old 08-15-2011 | 08:12 PM
  #1603
Andre Hedrick's Avatar
Andre Hedrick
Rest in Peace
Spent hours in shipping and US Customs to get my G28/12 out of import lockup and it is now home.
Old 08-16-2011 | 09:20 AM
  #1604
928mac's Avatar
928mac
Good Morning all.
I got to spend some time tuning the Tec-4 GT system yesterday after work and I am happy to say WOW! what a difference now that its tunable.
I have the fuel mixture where it sits around 12.5 to 13.5/1 on or off load and I am still not using the VE table or the EGO sensor (O2)
I am very pleased.
I still think I can get it to rev harder and faster by fine tuning the timing but I have to check the flight recorder and reset the knock sensor values.
Today should be a good drive to work.
Brad
Old 08-16-2011 | 10:01 PM
  #1605
jeff spahn's Avatar
jeff spahn
Put my super clamp on the flex plate. Had to use a crows foot to get the torque wrench on the bolts.
Quick Reply: So what did you do to your 928 Today......
