Twin Turbo 928 fixed and back out there terrorizing the streets!
#646
Here's the new turbine housing, pre surgery, next to the old one. It's going to flow more with less exhaust manifold pressure. The only problem is that the turbocharger unit needs to be cut and welded in three spots to fit in the space available. The old smaller turbos only needed one cut and weld...
#648
The turbos that I have now were already cut and welded on the compressor side by John's welding expert. This is a more challenging project, cutting that stainless steel housing in two places, adding an "internalish" wastegate, adding a flange that fits in the space, and then welding the jig-saw puzzle together again. Like putting humpty dumpty together again (to be remachined). Rest assured that I could not do any of that. I am focusing on understanding what is happening, and that is a challenge enough.
We will find out soon whether it is possible. So far, John is batting a thousand on turbo cutting and welding.
#649
Granted, I don't know the details or engineering specs of the setup, but would it not be "easier" to just run dual external wg's? I'm guessing space is really of the essence and that probably isn't an option at this point. I'm confident whatever you do, will. be. awesome.
#650
If this surgery works, it'll be awesome.
If it doesn't work, I'll be sad. But when I'm sad... ;-)
#651
New turbos
We're proceeding with a proof of concept with these slightly larger turbos. If the proof of concept is successful, I'll post more data. Both the turbine wheel and compressor wheel are larger. The challenge is to modify the housings to fit the available space and to integrate a wastegate to the exhaust housings.
Special thanks to Todd Tremel for additional motivation! ;-)
#654
Tuomo,
I'd be interested in seeing a pic of complete assembled turbine and compressor section if you care to share... I think I see the ext WG mount, and the faces of the comp/turbine seem clockable in portions of 72deg. I like the idea of V bands, and am curious about the compressor exit. Seems like a 3076 modified setup, but I can only guess from here... Interesting....
Best,
Best,
#655
32psi of back pressure for 20psi of boost make a ratio of 1.6, which is not perfect but far from excessive IMO. Spool must be excellent, but this is obviously missing the point since we don't need that much torque low down with a 5.0 engine.
That new turbo looks like a GTX3582R. I'm pretty sure the largest 1.06 A/R housings will work best with what you want to achieve.
#657
New turbos about to be hung
There's some progress to report on this topic. The new turbos are about to be hung. After all sorts of surgery, these GTX 3576Rs will fit without modifying the car chassis. Let's just say that this wasn't possible with components available year ago, and even with the newly available housings it's still a custom job.
Here are some photos and in the end there's a video link:
#658
Hoo Yeah that is big, It wasn't till we could see the turbo in situ to get some scale to realise just how sizeable the growth has been.
Best wishes guys, look forward to seeing the results.
#660
It's 99% John at this point. With these new turbos, I've basically done nothing except a little bit of math.
